last night use watch epl still going good.It seems not working anymore
http://www6.robyang.dpdns.organybody have the latest updated link as http://www.robyang.dpdns.org is not valid anymore.
hi gregory_choo, which website can see the above info in case the link get updated again
anyway to open it thru window?just come back here.
robert yang has no website.
Haha, you think so, maybe you are right in 2025, now is 2026 Robert is still Robert, anbox has move on very farThese 2 links are copied from Robert Yang .
Not so stable, works only for 2-3 months then have to change again.
Yes if you know how to run android apps in Windowsanyway to open it thru window?
Windows 10 and 11 have built-in android.
I use AnBoxTV_2.6.0 and tried first and last url input in Live: .Can see the channels list but when try to play any channels will show Time Out. Do you know why?
wanna find solution there is a chat group to post your issue, the members there will help youI use AnBoxTV_2.6.0 and tried first and last url input in Live: .Can see the channels list but when try to play any channels will show Time Out. Do you know why?
This a toxic group. Especially the admin. Always insults the members for asking 'stupid' questions.wanna find solution there is a chat group to post your issue, the members there will help you
https://t.me/+tFVWtr59tAliOWVl
Should be working by nowAre the links working for you guys? Mine no longer working even after switching around these 4.
dont waste your time on these links, there are much better oneAre the links working for you guys? Mine no longer working even after switching around these 4.
Is it ok to use fmtv with anbox links? The virus is from the anbox apk and not the vod live TV links, correct?The advantage of anbox 2.60 is that it is not necessary to put URL in the settings page. Since you are going to put links yourself, no reason to use anbox 2.6
On top of that, it has many problems. E.g. Cannot save the previously watched channel, cannot start with live channel by default. On top of that, you will see that it is infected by many viruses if you scan it with virustotal.
Robyang's links works better with later version of oktv/FmTV. The first few groups of live channel are using YouTube live feeds, but earlier version of oktv/FmTV cannot play them. Anbox is based on oktv 2.6, so it could be the cause of the problem.
I recommend the use of FmTV latest version. By the way FmTV is from the original developer. Oktv is based on FmTV. Oktv has some additional features but not needed by most of us. Furthermore,for some unknown reasons,it incorporated 5 to 6 viruses during the enhancement.
