Google Pixel 10 series
limmk
Loving my Pixel's camera, providing excellent photos of my trip. :love:
npnt | edmw animated gif
ba11er
The temperature sensor metal attracts dust and grime even if I don't touch it. Anyone else has this problem?
FatalethaL
I have not encountered this issue. It looks clean. But again, i like my visor clean clean. I tend to wipe clean twice or thrice a day.
Jurong640
Shopee customer receives unsealed Google Pixel 10 Pro XL after 6-day delay, gets full replacement
On 21 Dec, a Shopee customer took to the r/askSingapore subreddit to air their complaints about a recent purchase.
They alleged that not only had their order been delayed for six days, but that the Google Pixel 10 Pro XL arrived unsealed.
First time using Shopee over Lazada​
According to the customer, they had bought a Google Pixel 10 Pro XL from the official Google store on Shopee during the 12.12 sale.
While they usually would have used Lazada, they found the deal on Shopee more attractive this time around.
The customer first noticed something “fishy” when on 15 Dec, a deliveryman arrived asking if the phone was delivered.
When the OP said no, the flustered deliveryman tried to insist it had arrived.
He then left, claiming that he would check with his team.
ba11er
I really want to love this phone but so far the battery life has been diabolical lol
One week already and battery still draining excessively while on idle with all apps already limited background usage. Never had this issue with my P8P. Screen on time also horrendous, not even 3 hours and already at 40%
kEvinErd
Yea the battery life is really weak compared to other phones. Battery anxiety is the main reason I’m not able to use this phone. But you say the battery drains “excessively” while the phone is idling. How excessive is excessive? Relative to your Pixel 8 Pro?
ba11er
I dunno if this is considered excessive to people here bro. Went to bed at 70%, woke up 6 hours later and left with 58%. To me that is excessive drain leh. My P8P used to drain like 1% per hour at most idling?
kEvinErd
Eh this sounds excessive. Some rogue apps?
froztheart
Yes, already used to such battery life. Idle draining is much higher definitely compared to current standards basing from my usage.
hellhole
i think batt drain is probably app related... you should write to the app developer...
its the 'bad' of android phones.. as there is variants of android devices out there
froztheart
Nah, app usage are the same so can't possibly be that it's draining on P10PXL while not on my other Android phones.
