Aynone here using SIPTEL Cloud telephony?
pwongkk
How many lines you getting?
My setup for home using a single Starhub line with FreePBX and an ATA device. Cheaper.
Soomp!
You have to go with their 3 years of contract which I resist
keenklee
IMHO.
@pwongkk Do you reckon it is possible to connect the RJ11 line from 4G router to the ATA device ?
pwongkk
IMHO.
I saw some tiong routers supporting this.
I'm using the old Linksys SPA3102 and SPA2102 to do the interfacing. Myvsetup is Starhub -> ONT -> SPAx102 -> SPAx102 -> physical Cisco phone. Phone's SIP profile configured on FreePBX. The x in the SPA is either 3102 or 2102. Basically is configure and forget. The only negative thing about the SPA devices is there's no way to backup the configurations.
Served me well for more than 10 years. The only thing I changed was the power adapter which blew.
keenklee
IMHO.
I have on simple Prolink 4G router that has RJ11. Maybe i should try it. 🤔
keenklee
You got the model number? Can read up and tell you if it can be done.
IMHO.
It is Prolink PRN3006L. I connected a analog telephone before and it worked.
I was reading a bit, seems to plug in the output of the Prolink to the Linksys FXO (Line) port.
