soarskyhigh
- Apr 13, 2010
Crack first click til 1755
https://s.lazada.sg/s.24KLn
You can create your own, or use the one I provided.Awesome! I figured out a solution for the 5c tasks that weren't completing.
You can now complete the previously broken 5c tasks by scanning the barcode. I tested it over five times, and it worked flawlessly each time.
You must close the app, and then scan using your phone or the app's scanner.
But afterward, you have to reopen the app or click the pop-up notification after task completion to continue playing.
My three accounts are not working at all. I tried many different links, but the result is always the same.It's easier to close the app, click your own crack first link or someone else's crack link and then goto task lists (bottom left) and do the 5 cent task.
No need to use scanner... as the qr code is simply a link.
Oh.My three accounts are not working at all. I tried many different links, but the result is always the same.
I am now trying a different account, but I cannot complete the task using either the scanner or the link.
It seems different accounts need different methods.
