Lazada game
torroptan
Awesome! I figured out a solution for the 5c tasks that weren't completing.
You can now complete the previously broken 5c tasks by scanning the barcode. I tested it over five times, and it worked flawlessly each time.
You can create your own, or use the one I provided.
You must close the app, and then scan using your phone or the app's scanner.
But afterward, you have to reopen the app or click the pop-up notification after task completion to continue playing.
tmkedmw
It's easier to close the app, click your own crack first link or someone else's crack link and then goto task lists (bottom left) and do the 5 cent task.
No need to use scanner... as the qr code is simply a link.
torroptan
My three accounts are not working at all. I tried many different links, but the result is always the same.
I am now trying a different account, but I cannot complete the task using either the scanner or the link.
It seems different accounts need different methods.
tmkedmw
Oh.
Wish u Good luck.
Same laz game, but can be different prize structure, different game behaviour for different people.
There is also different tier of user that may play a part.
Try logout from laz, clear laz cache and relogin to see if that helps.
