- Jul 14, 2005
Siang kar my pager????Oh I remember myself and @KeYoKe chatting with u some time ago about this... we said there isn't any phone that fits all ur requirements remember?
Pixel 8a. Difficult to find nowPreferably with video-out and good camera , at ard 400-500 if possible
S25 FE was $495 on tg/bf/cm/12.12 forgot which onePreferably with video-out and good camera , at ard 400-500 if possible
FE is mid range, not flagship.this one consider flagship? sian leh why the ram 8gb nia![]()
Upper midranger bah, got more flagship features than missing themthis one consider flagship? sian leh why the ram 8gb nia![]()
tot they exited SG...blast from past! had a Realme GT2 Pro...looks like they partner with Ricoh for branding collab.Realme P3 5G - SD6gen4 - 8/256gb - global version at $266.28 (dunno how reliable this e-store is)
https://sg.shein.com/Realme-P3-8GB-256GB-5G-LTE-6-67-Inches-120Hz-AMOLED-Screen-50MP-AI-Camera-Unlocked-Cellphone-Andrid-15-Smartphone-Qualcomm-Snapdragon-6-Gen-4-4-Nm-5G-Chipset-5130mAh-Large-Battery-Cell-Phones-Christmas-Gifts-Presents-Global-Version-GSM-Only-P3-Lite-8GB-256GB-4G-LTE-6-67-Inches-120Hz-Eye-Comfort-Display-p-80543404.html?src_identifier=st=5`sc=realme p3`sr=0`ps=3&src_module=search&src_tab_page_id=page_goods_detail1767662451764&mallCode=1&pageListType=4&imgRatio=3-4&detailBusinessFrom=0-2&pageListType=4
Ya... how was the GT2 Pro?tot they exited SG...blast from past! had a Realme GT2 Pro...looks like they partner with Ricoh for branding collab.
First flagship phone for me ..the snapdragon 8 G1 sucked battery like crazy but everything runs smooth. Camera with 3 lens was good for 4 years ago, wide angle was impressive then.Ya... how was the GT2 Pro?
I had a Realme as well... Realme 9i... not bad a phone also...First flagship phone for me ..the snapdragon 8 G1 sucked battery like crazy but everything runs smooth. Camera with 3 lens was good for 4 years ago, wide angle was impressive then.
Support and updates were meh..that paper organic skin was interesting.
Have stayed on flagship cpu ever since![]()
Wah the price diff is a lot... is the configuration the same? If so, just go for the Fusion One lor...![]()
Is it worth saving the price diff?
Are you comparing the 16gb, 512gb to 16gb, 512gb?![]()
Oh my bad, yes u r right.Are you comparing the 16gb, 512gb to 16gb, 512gb?
The price for the Fusion One seems to be the 16gb, 256gb version. 512gb version is another $100 more.
It's about $200 difference. It's a borderline case. The extra $200 for the local warranty is the main thing to see if you want to go for local set. I don't use eSIM, so no eSIM for china set is not an issue for me, but if you need eSIM, then have to go local set.Oh my bad, yes u r right.
This is the 16/512gb price from Fusion
I think the Fusion One set is global set...It's about $200 difference. It's a borderline case. The extra $200 for the local warranty is the main thing to see if you want to go for local set. I don't use eSIM, so no eSIM for china set is not an issue for me, but if you need eSIM, then have to go local set.
If not urgent to get the phone, I would suggest to wait till CNY period. Might have better deals.
Probably flash rom from china set so the hardware don’t have eSIM..I think the Fusion One set is global set...
Think probably china flashed sets. Oneplus 12 & 15 some far china flashed sets not much issue. Only Oneplus 13 have issues every now and then. So more are selling the 15 china flashed sets.I think the Fusion One set is global set...
