FatalethaL
- Dec 17, 2008
Google Play system update available
Update size: 15 MB
On Google Pixel 10 Pro XL
Update size: 15 MB
Curious if you check daily/saw the update in the news or you actually get the update pushed to you via notification by the phone?Google Play system update available
Update size: 15 MB
All of the above.Curious if you check daily/saw the update in the news or you actually get the update pushed to you via notification by the phone?
You're my update notifier.All of the above.
Reddit, news, notification, manually trigger to check for updates.
Didn't expect this to happen to pixel.. tot usually is china rom/brand phones...after yesterday update for firmware, DBS app not working today for paynow, Pixel 10 Pro xl
I think google rolled it back. I checked and got update, but then the update didn't download at all and told me no update available.Jan update in for everyone? 9to5 noted that Jan security patch is out but there's no update when you click manually. Is it need to sideload the update or Google halted the update last min?
Ahhh ok! Thanks for the update. I thought only me, wondering why some peepo have the update already but me keep searching no have. Kam Xia!I think google rolled it back. I checked and got update, but then the update didn't download at all and told me no update available.
Luckily I haven't updated likely got some major bug.
No OTA available on my Pixel 10 Pro XL too!Jan update in for everyone? 9to5 noted that Jan security patch is out but there's no update when you click manually. Is it need to sideload the update or Google halted the update last min?
Ok wait for your greenlight.Just got prompted to restart for Jan 2026 update.
