Xiaomi 15 Series
dreamcast18
Juz dived in and gotto a pre-loved Telco 15U, haven't really set it up for use but 1st impression is 有重量!
congrats! did u get the camera kit too?
There's a gazillion manual settings on the camera...best results are not from P&S sadly. Need @RyanJ skillz to max full potential.
That said...for scenic landscape photos..the P&S is solid.
dev_stg_prd
which you all use ah?
For battery protection, you need to turn on to charge so that it will reach 80? Turn off will reach 100% instead ?
hermes76
yah, seller included the unused kit too, many casings and screen protectors, all below 1k, i think is a good deal there. i read Jupiter will be at her closest to earth tmr, let's see if I could capture anything with it. :p
dreamcast18
remember to use google sky map to find jupiter! I was able to get the Orion's Belt last week; but the light pollution even on an island was pretty bad.
hermes76
i'm using Stellarium...wonder is there any good telescope attachment like those for the Vivo X300 Pro
RyanJ
@RyanJ tried one. I think u can search for his review.
I've tried Ulanzi and Neewer ultra wide angle attachement with 17mm screw thread, vignettes ever slightly on the 23mm 1 inch sensor, and the peripheral image quality is visibly bad at least for me.
( Was hoping to harness the full 1 inch sensor goodness for ultrawide but failed )
Have not tried a telephoto attachment yet, hardly do anything longer than 4.3x.
dreamcast18
Taiwan region also gets HyperOS3 for 15U. Immediate push when switched to TW.
per @speedknight India region works too...but I prefer TW 😅
dreamcast18
Something is wonky... After update this menu of functions are greyed out for me in Chrome
Solution: Hit the ... to re-enable the menu.
