Nothing Phone (3)
halocast
899 still seems expensive... :o
unnecessary changes that should have gone to other parts of the phone. :o
Could have a winner but carl lost it.
anthonygreenisreal
The usual shops are selling around 950. Still not low enough. I've seen 850 bit it's used.
I've seen new one selling on Shopee for $850. At this price I also think not worth it. Maybe below $650 I might bite.
OnePlus 13 512gb is also selling for around $850 during the last sales on 9.9
simply.90
Ya they really misjudged the situation, some things can scrimp on, but some really cannot, and attach a silly unrealistic RRP.
Some more their USP is design but this design is not that, and imo NothingOS is getting stale, especially if you couldn't care less for their Essential Space and AI stuff. The important thing for AI is the ability to have local offline Gemini models, but obviously you'll need the SD Elite or Tensor which are supported, and this phone doesn't have it.
shager
Ah you're right. I think it may have been Urban Republic. I remember now seeing it priced lower than the other shops.
Yes that's the problem with a lot of phones - they're poor value compared with OnePlus 13. It's a pretty good all-rounder phone and now can be bought at a great price.
peterg
I manage to grab a few codes, dm me if you're interested, blanja me a double mc spicy meal jiu hao le:flash:
dont ask me how i get the codes ya
The only draw for Nothing Phone (3) would be the Black Card that is given with the Phone (+1 year warranty) which apparently isn't available in other countries that sell this one.
Thing is, only this and CMF Phone 2 Pro here have this given free with purchase, if you know where to get it first, so......
Worse still, Nothing Phones need OTG for extra storage which for me is a deal-wrecker as well......
Fellowes
Carl Pei: "AirDrop is now compatible with Android! This is the kind of progress we need to see.
We’re already exploring how to bring this to Nothing phones as soon as we can."
Fellowes
Nothing OS 4.0 begins rolling out today starting with Phone (3) and will expand to the rest of the Nothing smartphone lineup over the coming weeks, and to CMF smartphones by the end of the year Phone (3a) Lite will follow early next year.
limmk
📱 Nothing Phone (3) - Nothing OS B4.0-251224-1229 Changelog
Feedback? On your device: Go to Settings -> System -> Feedback.
Firmware rollouts are usually staggered, meaning not all users will receive the update simultaneously. This approach allows us to monitor for any issues and ensure a smooth and stable deployment.
What’s New in This Update
Visual Enhancements
🔋 Updated the battery percentage icon with the number displayed inside.
🌑 Optimised Extra dark mode for better visual adaptation to more scenarios.
🎚️ Improved the smoothness of the volume slider animation when adjusting volume via keys.
📼 Optimised sound wave and wheel animations in Recorder for a more fluid experience.
General Improvements and Bug Fixes
🔔 Setting different ringtones for dual SIMs is now supported.
👀 Always-on Glyph Toy now will always stay on until manually turned off.
🚗 Fixed an issue where the in-car display could freeze when using Android Auto.
👖 Improved pocket mode detection logic for Glyph Interface.
📳 Optimised the vibration and haptic feedback across more scenarios.
🔒 Enhanced stability of lock screen and AOD for a better experience.
🤳 Improved Glyph mirror stability across more camera scenarios.
📹 Fixed an issue where the video encoding setting reverted from H.265 to H.264 when switching between shooting modes.
🚶 Fixed an issue where the Pedometer Progress widget continued animating on the lock screen while AOD was on.
🛜 Improved the searching speed for nearby available Wi-Fi networks.
⚙️ Enhanced overall system stability and smoothness.
🛡️ Updated to December security patch.
Notes:
The device may temporarily heat up and increase power consumption during the update and will quickly return to normal after the process is complete.
// nothing.community
Shadowz1984
The pricing is the main issue of the phone. If it's priced around $700 to $800, then probably still can consider.
