uncle_josh
Eight 4G network smh cannot even do basic google search cuz every attempt kena captcha bot sia. Moi now try to use openvpn to home router, seems to bypass it.
So for those who struggle with it can try too.
Setup "dns.adguard.com" under private dns section on your device to get rid of all these stupid captcha bot.
Eight like the parent company, StarHub, inherit the problematic dns gene cannot use one . Always need to set 3rd party dns.
iPhone can do it, but you need to create a custom DNS profile and install it on your phone. It’s a few extra steps, and the article below explains the process though it might take a bit of time to fully understand.
👉 https://adguard-dns.io/en/blog/encrypted-dns-ios-14.html
Take note this method may not work if iCloud Private Relay is used.
Reference
https://docs.quad9.net/Setup_Guides/iOS/iOS_14_and_later_(Encrypted)/
When using iCloud Private Relay, most VPN clients, or Little Snitch, it will not utilize/respect this DNS profile.
  • VPN: do not follow these instructions. Instead set Quad9's IP addresses in the Custom DNS settings of your VPN client. Refer to your VPN client's documentation for further information.
  • Apple Private Relay: do not follow these instructions. Apple private relay will use its own DNS servers at the system level, with no way to override it.
hengheng69
Last month port in failed due to some issue , went ahead to top up the temp number ($88 + $88) and get the free 3 months , finally port in to eight today . all good now . :ROFLMAO: :ROFLMAO:
Rather they improve signal at the west side. SH 5G damn cui at the west
Unfortunately eight cannot do much here. They need the help from the parent company StarHub.
1) Improve the 5G Radio Access Network (joint venture between M1 and StarHub)
2) Improve the 5G Core Network. eight/giga 5G will have lower priority than the StarHub 5G Unlimited+ plans.
3) Improve the 4G core network to improve the congestion situation of StarHub 4G network when 5G is not available (or for eight 4G plan). But looks like this is a low priority for eight and they are trying to push people to 5G.
gapboy
🚀 Great News! Your 5G plan just got even better! ✈️
You have previously voted, and here's the surprise we have installed for you. Instead of just one destination, we are giving you MORE.
Lucky Eight Plan: Now with China & Korea!
Triple Eight Plan: Now with China, Korea & Japan!
These destinations are added on top of your existing APAC roaming data (28GB for Lucky Eight, 36GB for Triple Eight) for Malaysia, Indonesia, India, Thailand, Vietnam and Taiwan, absolutely FREE!
Just turn on roaming & stay connected easily! Travel worry free with eight!
We got you covered! 🌏
jess_sy
Nice that's even better value!
chaiscool
Lol my 1st read maciam they say china, korea & japan roaming now unlimited free sia haha
