Xiaomi 15 Series
caterham7
i did all of these but still get some prompts here and there. am i missing something?
more details needed
e.g. which apps or which scenarios are u seeing ads?
btw, can also consider using private dns, that also helps when surfing online
example below, i use Option 2. besides adguard, there are other dns options also
https://adguard-dns.io/en/public-dns.html
dev_stg_prd
Btw, for singpass ( tap on qr ) , do you guys have issue ah? You tap on it got issue come back to original page? Do you all set chrome as default browser as workaround?
Btw z I prefer edge
speedknight
Moderator
Moderator
Btw z I prefer edge
Nope no issue. I also using edge cos my work stuff all Microsoft base. Edge also got the advantage of syncing everything from my Desktop, Phone and ipad
dev_stg_prd
Can I check, if you set edge as default and singpass tap no issue? Or is it some anti pop ups blocking ah
dev_stg_prd
what is your
Default apps > Opening Links > 1) did u check Instant Apps ?
2) for Singpass is Open and In the app selected?
speedknight
Moderator
Moderator
Mine this always appear i.e
use app or use external <-- this selection pop up , this could be the setting if yours didn't have this appear.
I think is something similar. It will prompt something initially. But I forgot what exactly it was. Then if select it once, it will be automatic next time.
dev_stg_prd
btw I think my charger has issues..
it states quick charging and full charge is slooow. what about you guys>
jeff79
Is edge settings> site settings> block opening external app. Needs to turn off to open singpass app from other apps.
