Finally went back to try Linux.
rtfm38
Use Ubuntu because wanted to try hyperland and niri (window tile managers) and installing those on ubuntu is easy.
Played around with Linux over the years but always got some issues here and there that I'm too lazy to fix and of course back then, gaming wasn't very well supported and there's no Chatgpt to help you.
I'm kinda surprised at how fast and seamless current iterations of linux distros are now. I'm not even using the leanest distro (like arch) out there and already I feel it is much snappier than Windows 11 and of course it's not spying on you and selling your information.
Not going to lie, there are some hiccups in the beginning because I use torrent to download the distro and had some issue installing ubuntu but after redownloading it and creating a bootable usb, did it install correctly, had some issues with sound as well but that's because of Niri and got it sorted with Chatgpt help. Even downloaded steam and try to play some games which ran without any issues, although the loading times are slightly slower than on win11. Of course games that require kernal level anticheat programs won't run on Linux, there are workarounds but I'm too lazy to go down that route. So currently I'm dual booting win11 and Ubuntu.
If you don't require any particular windows-only programs to work and just do general internet surfing and use online tools like google docs or Afinity (which is an excellent free alternative to photoshop) then I would say Linux as it is today is more than capable of meeting almost all your needs.
I set my computer to boot into Ubuntu/Niri by default and when I want to play some games I reboot into win11. Side effect is that I'm not gaming as much and a little bit more productive because steam is not just one click away.
having said all that, of course depending on your hardware, your experience may vary, some windows programs that you want to run in Linux through wine have weird issues like needing discrete graphics and won't work with integrated graphics. Of course all these issues are easier to resolve if you like to tinker a little bit and get some satisfaction solving problems. If you can't stand tinkering and using the command line then better just stick to windows.
it_geek
Are u using x11 or Wayland as your display manager?
X11 is damn stable but they pulling the plug in favour of Wayland, means legacy systems jialat liao
rtfm38
wayland and yeah, that's why got the sound issues.
matt1618sg
Linux is more innovative than Windows. Eg, use btrfs instead of ext4. Windows has been stuck with ntfs forever. Try immutable Linux distros like Fedora Silverblue. Eventually Windows will copy these Linux features. Eg only in Windows 10 do you get a package manager (winget); Linux has had package managers for decades.
batuchka
speaking of integrated GPU i once installed Q4OS Trinity DE super light weight can run on ancient AMD HD 4250 IGP on a 2009 rig sio (y)
xdivider
If u wanna game, try bazzite.......
tmkedmw
u neh do what your nic suggested ... rtfm
enimen
If I only have 1 usable PC with no OS, how can I install Linux os on it without any OS in the PC? Any idea?
Jack_Chen
I have tried various distros
Debian
Ubuntu
Mint
Pop OS
and others which I can't remember.
The odd thing is, in past, you can actually burn the Linux OS into a CD and then run a 'Live' CD to test out the OS.
I did it with Debian and Ubuntu, both work from the Live CD but Debian experience drivers issues the moment I did full installation. I think you can still do this by booting into a USB drive
Ubuntu did a lot of Groundwork for you in the past, then they withdraw support for a lot of things and also push for SNAP, end up, I just gave up.
Mint was great when I came out of Ubuntu but it is not really for me.
Pop OS, although also based on Ubuntu, managed to overcome the drivers support issue and can install without much manual intervention. A great distro if you want general use and maybe gaming. Good for those with large STEAM libraries.
Jack_Chen
You are talking about installation from scratch?
First create a bootable USB Drive loaded with the Linux Distro of your choice. (you need another machine to make the drive or someone to help you do it)
In your PC, configure BIOS to boot from USB and then plug in your Linux Thumbdrive.
follow the instructions once you boot into the Linux Distro. (I recommend POP OS for the least headache)
mooseolly
It is like using GIMP (free and open source) vs Adobe Photoshop. Both can do the work but the paid one is easier to use for the mass.
