jogging and motivation thread
xllms
How about trying 3k. I really like 3k, just that it is not quite a sexy distance coz virtually nobody doing.
6k actually i feel is a little bit on the long side.
For core, i recommend as a runner, push up first. I started with only being able to do 5 push ups in 2022, believe it or not. Then i touched max of low 60s......trained with weighted via bands and diamonds and wides and partial reps, but wrist pain coz the bands pull the wrists upwards. I then changed to dips, which i find also really good, actually is tougher than push ups. No pain liao.
Can also try pull ups / scapula pull ups and then deadhang after X number of reps....... or jump up and isometric hold at top of the bar, 2/3rd way halfway, 1/4 way slowly negative down. Is enough liao.
If got above, regular planks not necessary, but i am not sure if side planks are beneficial for your ex-conditions. Can try 30-60s.
I can tell ya, if you train these, seeing you improve in reps is quite addictive, is significantly more addictive and supportive than even doing running esp since your running has stagnated. It sets the mindset straight as well, that it is possible one, it's not about your age. Coz it is positive feedback with results.
I like 5-6k for the following reasons:
a) 1st km: HR is lowest to push to the fastest pace
b) 2-3km: slowly get into the rhythm
c) 4-5km: feel the strain and good for threshold endurance
d) last km: push all the way
e) I have 2 dedicated routes that fit this run pretty well, one is all flat, while the other has a manageable slope at around 3km mark for a good workout.
For 3km, can do as well, probably will have to do more 3Ks to pile up the mileage 😂
WussRedXLi
For 3km, can do as well, probably will do more to pile up the mileage 😂
3k as workout then you slow jog down to zone 2 for another 2k ok liao. First 1k warm up. Total 6k. 🤣
Coz main thing if wanna try is to see if neuro is the limiter, dont let volume dictate things for a change so no fatigue at all. Your weekend LSD to maintain aerobic system already there.
Maciam like tapering phase, but even lower in intensity but more focus on neuro and power. (power is force or strength times velocity
xllms
this approach is what I have been doing to many of my 10k runs via a 5km to-fro route. First 5km quite fast and went all out final 400m stretch with a gradual pick up from 4km mark onwards. Then slow down the pace for a return 5km warm down run. At times mix abit with a final 2km threshold run after i cross the slope at the bridge with a final 400-500m sprint.
A higher intensity of what you suggest, perhaps
WussRedXLi
Such a good spread of nutrition products
Heat training with a CORE heat suit/sensors as well. (Lucy Charles Barclay using also)
Usage of whey and creatine post workout
dev_stg_prd
I did my usual 5K and use my xiaomi band. I got 4X Vo2 Max.. chatgpt told me it's conservative.. so expect + a few points. so according to this it's good . https://www.fitnescity.com/understanding-vo2-max
so usually when one is active, be 'default' is good and it's not unexpected rite?
SpeedingBullet
I have heard from videos that it is within 2 points though Garmin tends to overestimate the vo2 number. Where did you go and test?
Coached! They got a lab in CBD. Perfectly convenient.
Garmin actually underestimated mine. It est. mine at 52, my test I got 53. But still hats off the Garmin’s algo lah, to be so accurate
WussRedXLi
40th place, it's a must to cry. Heng not like last time with Samurais
Turn on the CC btw
Documentary by Tempo
noinimod
Anyone here with wider feet especially in toebox area and having success with china shoes?
For reference, i tried a few Linings but it's too narrow in toebox for me. Anta was marginally wider than Lining but still felt quite narrow. Dynafish xiaonian was surprisingly more roomy than Anta/Lining. New balance 2E works well for me
Mecisteus
That's close enough.
Make sure max HR is correct on Garmin. Otherwise, vo2max estimation is out.
Anyway I don't put too much hope on vo2max.
My vo2max can be higher than you but I know my aerobic fitness or endurance is not as top as you. :s13:
SpeedingBullet
Ya i did lactate test years ago and adjusted HR accordingly, so i guess thats why the number is really good.
vo2max only measures maximum output, when ppl run endurance (or even tempo) they dont go anywhere near it. it's just a number lah
WussRedXLi
BTW it just hit me, last time were you doing your intervals at the correct paces? To develop the correct energy system and improving your LT2 and LT2 "curves". Also assuming work:rest ratio more or less there and not totally off.
Can use this if you have been doing some TTs along, pretty reliable way.
https://runbundle.com/tools/running-training-paces-calculator
sales69
Same previously NB size 10 2E.
If D width, I would size up 1/2 size. Recent years, their last getting narrower so go 1 size up.
Now wearing Bmai and Qiaodan size 44. Width is good enough, not tight.
Xiaonian wearing 44 as well.
