WussRedXLi
- Jun 15, 2001
Mary go go go !
1:28
1:28
this approach is what I have been doing to many of my 10k runs via a 5km to-fro route. First 5km quite fast and went all out final 400m stretch with a gradual pick up from 4km mark onwards. Then slow down the pace for a return 5km warm down run. At times mix abit with a final 2km threshold run after i cross the slope at the bridge with a final 400-500m sprint.
A higher intensity of what you suggest, perhaps
Same previously NB size 10 2E.Anyone here with wider feet especially in toebox area and having success with china shoes?
For reference, i tried a few Linings but it's too narrow in toebox for me. Anta was marginally wider than Lining but still felt quite narrow. Dynafish xiaonian was surprisingly more roomy than Anta/Lining. New balance 2E works well for me
don't think i bothered too much about techniques.BTW it just hit me, last time were you doing your intervals at the correct paces? To develop the correct energy system and improving your LT2 and LT2 "curves". Also assuming work:rest ratio more or less there and not totally off.
Can use this if you have been doing some TTs along, pretty reliable way.
https://runbundle.com/tools/running-training-paces-calculator
| Pace | From | To |
| Easy/long | 8:02 mins/km | 6:38 mins/km |
| Sub-threshold | 6:26 mins/km | 6:06 mins/km |
| Threshold/tempo | 5:51 mins/km | 5:45 mins/km |
| Interval/VO2 max | 5:18 mins/km | 5:05 mins/km |
| Speed endurance | 4:51 mins/km | 4:11 mins/km |
| 1000 metres race pace | 4:50 mins/km |
Thanks for sharing! Your NB size 10 2E is UK10 or US10? Which Bmai and Qiaodan model are you using?Same previously NB size 10 2E.
If D width, I would size up 1/2 size. Recent years, their last getting narrower so go 1 size up.
Now wearing Bmai and Qiaodan size 44. Width is good enough, not tight.
Xiaonian wearing 44 as well.
NB was wearing US10 2E. Or US10.5D to 11D.Thanks for sharing! Your NB size 10 2E is UK10 or US10? Which Bmai and Qiaodan model are you using?
Can ask what is your number? Coz I have a feel those mostly in the 50s range for Garmin are mostly off in Singapore. But 60+ are still fairly accurate from YouTubers test.Garmin’s VO2max number is quite legit.
i just did my VO2max test and it came within 1 pt of it!
Edit: Just saw your other post , it's 53.
My impression on on why 50 isn't accurate is because I see a lot of local runners with about 50+ in garmin, but their 10km and 5km PB are far off from expectations when using vdot.
Could be, but for season runners, Re can't be too far off. Even if account for RE, a few points maybe. I have see vdot of 10 points difference. Unless I am wrong in my assumption, and RE factor can be such significantly off.Maybe RE and LT lousy lor.
My 5k and even 3k F type for the VO2max number i got, more than 5 points off.....how accurate is my Huawei, not sure.
Cardiovascular is can tahan, but not the limiter?
can i provide a data pt
vo2 max - 54 garmin
2.4k - 9:18 (2025 early mid)
5k - 22:28 (2024)
10k - 46:08 (2025 year end)
21k - 1:43:50 (2025 year end)
so am i below, at or above my vo2max
Usually I just base on 5km and 10km. HM too much endurance factor. But 2.4km would be more accurate to reduce endurance factor. But vdot chart doesn't have a 2.4km. using your 5km and 10km puts you in the 44 for vdot. Vdot assume your running economy of 1, it should be fairly accurate for season runners, with a few points off. But not cyclist or other discipline.can i provide a data pt
vo2 max - 54 garmin
5k - 22:28 (2024)
I think sweet spot should be the Cooper test, for season runners without carbon plate shoesFor me, the "curve" is that 5k really off, yeah you said 10 points plus minus, then that difference gets less as we go to 3k/2.4 mark, and then even less for 800/1k/1.5 (not that i run 1-1.5k regularly, so as far as experience/skills in this goes i not there)
But then i am not a terribly seasoned runner, long, middle or short distances, i just run.......but that's my "curve" that i can share. 5k is biggest margin, then margin goes down as we approach 1k. I cannot say for things like 400m etc, those so short that really need track.
So yes, you might have a point in that observation of yours, at least for my 5k.
edit - oh yes, for 400m, the difference is just 3.5 points. Not that 400m is terribly useful in the first place, coz i only have "TT" experience 3 times only so is super noob, ie i only tried 400mm as TT 3X.But then without such experience, can get to 3.5 points, maybe that tells a story as well.
But of coz, also, for such shorter distances, anaerobic/ATP-PC system plays more of a part in %
I no run 800m before, not even once.
