- Jun 14, 2004
Still will have one just alot lesser
more details neededi did all of these but still get some prompts here and there. am i missing something?
What prompt u getting?i did all of these but still get some prompts here and there. am i missing something?
Tks I'd use thismore details needed
e.g. which apps or which scenarios are u seeing ads?
btw, can also consider using private dns, that also helps when surfing online
example below, i use Option 2. besides adguard, there are other dns options also
https://adguard-dns.io/en/public-dns.html
Let me kena another time I shareWhat prompt u getting?
no issue. once cleared app or OTP...BAU.Btw, for singpass ( tap on qr ) , do you guys have issue ah? You tap on it got issue come back to original page? Do you all set chrome as default browser as workaround?
Btw z I prefer edge
Nope no issue. I also using edge cos my work stuff all Microsoft base. Edge also got the advantage of syncing everything from my Desktop, Phone and ipadBtw, for singpass ( tap on qr ) , do you guys have issue ah? You tap on it got issue come back to original page? Do you all set chrome as default browser as workaround?
Btw z I prefer edge
Can I check, if you set edge as default and singpass tap no issue? Or is it some anti pop ups blocking ahNope no issue. I also using edge cos my work stuff all Microsoft base. Edge also got the advantage of syncing everything from my Desktop, Phone and ipad
Mine this always appear i.eNo issue might be the pop up settings iirc I had issues, go play around with your edge settings. View attachment 54291
use app or use external <-- this selection pop up , this could be the setting if yours didn't have this appear.
btw I think my charger has issues..
it states quick charging and full charge is slooow. what about you guys>
Is edge settings> site settings> block opening external app. Needs to turn off to open singpass app from other apps.Can I check, if you set edge as default and singpass tap no issue? Or is it some anti pop ups blocking ah
tks let me tryIs edge settings> site settings> block opening external app. Needs to turn off to open singpass app from other apps.
let me try again with og 90w charger + og cable. tksAre u using the original 90W charger and cable? Bring it back to XM lavender.
anyone?anyone did this for their 15T Pro?
https://xdaforums.com/t/how-to-debl...s-tutorial-video-2-ways-methods-2026.4775822/
