- Jul 29, 2003
It show for me.
It show for me.
Ok, using mobile i can still see.
Not activated yetZero1 and vivifi both indicated 5G+ on their plans. Vivifi got 5G+ launch bonus. I don’t seem to get 5G SA yet though. Anyone successfully connected on 5G SA liao?
not available still NSAZero1 and vivifi both indicated 5G+ on their plans. Vivifi got 5G+ launch bonus. I don’t seem to get 5G SA yet though. Anyone successfully connected on 5G SA liao?
what phone are you using? If you are on android, you can go network info to see if it's connected to NR SA or NR NSA. If it's NSA, then it's 5G NSA.Upgraded from their 4g plan to Streamo Freedom (5G), got this in my email.
"We are pleased to inform you that the following add-on service has been activated successfully with immediate effect.
Existing plan: Streamo Freedom
Add-on service: 5G SA HLR"
My android phone shows Vo5G on the status bar as well so I'm guessing mine is 5G SA already?
Using Oppo Find X9 Pro.what phone are you using? If you are on android, you can go network info to see if it's connected to NR SA or NR NSA. If it's NSA, then it's 5G NSA.
This VAS is active for Streamo Freedom users since Oct 2025 so it doesn't mean much.Upgraded from their 4g plan to Streamo Freedom (5G), got this in my email.
if you navigate to about phone, i think under SIM status, you can see if it's NR SA.Using Oppo Find X9 Pro.
My Sim Status shows NR only.if you navigate to about phone, i think under SIM status, you can see if it's NR SA.
May i know, if you did a SIM change previously, or you sign up recently?
Easiest way is to download nPerf app and do a Speedtest. U will be able to see the connected network at the app’s bottom info bar.My Sim Status shows NR only.
I did an esim to psim change last month (was still on 4g), then recently did a plan upgrade
It says 5G (SA). Nice!Easiest way is to download nPerf app and do a Speedtest. U will be able to see the connected network at the app’s bottom info bar.
