Zero1 Mobile discussion thread
Jurong640
trying out the 5G SA, the Band 78 seems quite weak (at my room). nPerf speedtest can't load (can't even press start to do test. Using Speedtest app sometimes fail. Only when it drop off n78 then can start doing test. But it remains at 770mbps download speed. Stark difference from my 1gbps download speed of 5G NSA. Summon airplane also no use.
sango65
maybe need @xiaofan to test his Singtel True 5G Sim-Only plan at $15.28 against Zero1 5G SA (if he buy a new line) side-by-side and check if Zero1 5G SA has lower priority against Singtel 5G.
gapboy
maybe need
@xiaofan
u can check his speed test thread ..
remembered he said he using cmlink which is the closest ..
ignore this..
Qubicfactor
I think for your case the base station for sa is further away than the nsa base station. Which is unfortunate.
Jurong640
No ma cos tot it's sperate since there is 600Gb for Malaysia and the 20gb APAC
it's okay.
I mean who knows, next time things progress for JS-SEZ. One will not be roaming when you are in JS-SEZ. It will be roam like home, using your local data in JB. Something like Simba's SG-MY-TH-ID-HK data.
