- Jul 29, 2003
Zf7. I dun have s25u.
I guess it alternate based on signal strength.
you are correct...weaker place shows volte ... near mrt shows VO))5G
ignore this..
Does your network cell info shows NSA?
Otherwise, summon the airplane.
maybe need @xiaofan to test his Singtel True 5G Sim-Only plan at $15.28 against Zero1 5G SA (if he buy a new line) side-by-side and check if Zero1 5G SA has lower priority against Singtel 5G.trying out the 5G SA, the Band 78 seems quite weak (at my room). nPerf speedtest can't load (can't even press start to do test. Using Speedtest app sometimes fail. Only when it drop off n78 then can start doing test. But it remains at 770mbps download speed. Stark difference from my 1gbps download speed of 5G NSA. Summon airplane also no use.
maybe need
@xiaofan
he has no interest in getting ST MVNO i thinkmaybe need @xiaofan to test his Singtel True 5G Sim-Only plan at $15.28 against Zero1 5G SA (if he buy a new line) side-by-side and check if Zero1 5G SA has lower priority against Singtel 5G.
I think for your case the base station for sa is further away than the nsa base station. Which is unfortunate.trying out the 5G SA, the Band 78 seems quite weak (at my room). nPerf speedtest can't load (can't even press start to do test. Using Speedtest app sometimes fail. Only when it drop off n78 then can start doing test. But it remains at 770mbps download speed. Stark difference from my 1gbps download speed of 5G NSA. Summon airplane also no use.
Yeah indeed. It's okay, still quite fast 770mbpsI think for your case the base station for sa is further away than the nsa base station. Which is unfortunate.
A more than worth it tradeoff. You won't notice 700mbps vs 1000mbps on a phone during daily use but a difference in battery life you definitely willAfter changing to 5G SA my phone battery improved a lot.
to me same same .. but differentAfter changing to 5G SA my phone battery improved a lot.
Maybe it's time to change phone.to me same same .. but different
s25u still one of the top phone .. no money like you for x300 proMaybe it's time to change phone.
Not strange. But it's good. Maybe part of JS-SEZStrange. Now in JB but uiliting the local data
No ma cos tot it's sperate since there is 600Gb for Malaysia and the 20gb APACNot strange. But it's good. Maybe part of JS-SEZ![]()
it's okay.No ma cos tot it's sperate since there is 600Gb for Malaysia and the 20gb APAC
For me I prefer to be speratedit's okay.
I mean who knows, next time things progress for JS-SEZ. One will not be roaming when you are in JS-SEZ. It will be roam like home, using your local data in JB. Something like Simba's SG-MY-TH-ID-HK data.
