Lazada game
tmkedmw
Create / Visit from shortcut not working for me, even after opening game from a newly created shortcut.
Anyone else the same?
Paiseh. Dig old post.
I need to install shortcut for gogo and Merge on Android home screen. Pls advise how to do that ?
888blancgmail
Home screen widgets
Scroll to Lazada
  1. Touch and hold the Home screen, and then tap Widgets.
  2. You'll see Recommended widgets at the top of the screen; swipe up to view the additional widgets.
  3. Select a widget, and then select your desired widget option. ...
  4. Tap Add to add the widget to the Home screen.
