koreanlover
- Aug 6, 2004
Thanks. I already done widgets.Home screen widgets
Scroll to Lazada
- Touch and hold the Home screen, and then tap Widgets.
- You'll see Recommended widgets at the top of the screen; swipe up to view the additional widgets.
- Select a widget, and then select your desired widget option. ...
- Tap Add to add the widget to the Home screen.
That I dk.... I don't hv too.Thanks. I already done widgets.
It's the shortcut (not widget) to merge that I still can't figure out
I posted the changed edited post@soarskyhigh, did U post b4 Pocoyoz, got pop up again?
cannot seeI posted the changed edited post
Nvm I will post a Lazdaily swe if it works?
Hi
