- Jul 29, 2003
Done liao. Looks like connected to SA once i moved out from office. Did a speedtest. No difference from nsa
In office sure get NSA ..me too
ignore this..
On esim.I got the 5G deactivation ln and 5G+ activation sms 40 mins apart. Now I am on 5G SA. Are you on non SA sim card?
The funny part is SA was meant to boost indoor but if NSA only while indoors. What’s SA doing to cover.
Likely 4G. We shall see…
Probably you replied to your own question, the two key words.why this mentally unstable guy reacting to every post
incoming SMS is free, can keep thatThis vivifi is good but they charges insane incoming and outgoing calls rate when you are overseas.
I just accidentally pressed a call to this bloody one motorist hotline.
It is an automated answer system and I will be charged S$ 6.30 for just maybe 1 second of call.
To use this vivifi better
1. Disable all IDD
2. Disable all incoming SMS and phone call
If not don't be shocked that your bills have a surge.
It's ur fault actually.. singtel m1 starhub zym zero1 heya Maxx cm link all the same bcoz no idd or voice roaming bundled...This vivifi is good but they charges insane incoming and outgoing calls rate when you are overseas.
1. Disable all IDD
The amount of roaming data nowadays is just…
The roamax plan looks better with more data at the same price of Asia super
quite normal to remove since 4g is not 5g+ plans, especially those plans below $10wow they removed the 6 months of free 5G for the cheaper 4G plans...
IIRC, removed since end of last Dec, in anticipation for 5G+ launchwow they removed the 6 months of free 5G for the cheaper 4G plans...
Was referring to the cheaper $7 4g plansJust wondering what do you mean by removal?
The S$10 VIVIFI Vibe 4G plan still shows the following.
https://www.vivifi.me/vivifi-vibe/?plan_id=1
- Free 5G+ Access (6 months) for new VIVIFI numbers & non-Singtel Port In
VIVIFI VIBE
@ $10/mth
[Free] +188GB* Roaming Data to Malaysia & Indonesia (one-time, valid for 365 days)
Additional Perks
- 300GB Local 4G Data
- [Free] 600GB Roaming Data to Malaysia & Indonesia (one-time, valid for 365 days)
- 588 Outgoing Local Minutes
- 100 Outgoing Local SMS
- 12GB Roaming Data to 13 Destinations:
- Malaysia, Indonesia, Thailand, Japan, South Korea, Australia, China, Hong Kong, Macau, Philippines, Vietnam, Taiwan & India
*188GB MY/ID (CNY Special): For New numbers / Non-Singtel port-ins (excl. Heya/hi!, GOMO, Singtel)
- Free Incoming Calls (on Singapore network)
- Free Incoming SMS (Globally)
- Free Caller ID
- Free SIM Card or eSIM
600GB MY/ID: Available to all customers
