jogging and motivation thread
cherynsq
For 5km run , because of the lack of stamina , I can only keep to zone 2 . Sometimes feel like walking instead of the slow jog as leg calf muscles feel very tight
but just continue to push on for weight loss . The other day took out my kebaya, can fit but slightly tight hahaha
I’m using Nike vomereo 15 in my rotation as it has zoom air and zoomx and react foam to keep structure intact .
WussRedXLi
Actually if that's the case, can try racewalking first also. Or alternate bt the 2.
You can slowly progress to faster racewalking speeds, the gait for it enables you to do 4:00 pace even.
Pro racewalkers do 20k at around 4:15 pace, and for even shorter distances like 1.6k, under 3:30 pace.
For shoes, just avoid the super high stack shoes and as long as no hotspots, can liao
Racewalking generally lower impact and injuries than running, but still, progressively load it up if you wanna improve on the distance and pace......just that it generally is more forgiving.
Kuudere
Yeah, easier, not as much plyo explosiveness needed or some skills/technique (SBJ). or min absolute strength (pull ups). Ok i mean, push ups also need absolute strength, but push up vs pull up is quite a significant difference for "novices", one is like maciam 1/2 BW while the other is full BW, other than the push vs pull aspect.
For middle aged runners, try to aim for at least 12:20 i guess, or around 5:10 pace i think. Dont aim for just passing ba.
2.4km standard at 45/49 y.o
45 pass<= 14.5049 pass<= 15.10
45 bronze<= 14.0049 bronze<= 14.20
45 silver <= 12.1049 silver<= 12.30
45 gold <= 11.1049 gold<= 11.30
45 commando gold<= 10.5049 commando gold <= 11.10
45 max <= 10.0049 max <= 10.20
Pass: 25 points
Pass with incentive/bronze: 30 points
Silver: 38 points
Gold: 43 points
Commando gold: 45 points
Max: 50 points
If you are focusing on weight loss, cut back on your easy pace by 10s/km for the 5k. You will run 50s longer for each 5k and burn more calories
noinimod
Hmmm if you feel the calf muscles very tight due to slow jog, it's probably too slow and ground contact time too long.
You may be better off jogging faster, then walk. Repeat that jog-walk cycle. It will feel better on your leg muscles than the ultra slow zone 2 slow jogging all the way.
For most average folks i dont think zone 2 training is sensible because the pace is too slow and overall jogging experience plain sucks. All the youtube/online chatter about zone 2 training really applies mostly to trained individuals imo
cherynsq
i sent my apple health record to gemini. it says i should take smaller steps as my Steps Per Minute too little. meaning i use longer stride. hmm the side of calves also very ache after each run
noinimod
Okay, means your cadence too slow and you're over striding.
Try to gradually increase it to 160 upwards to 170. At jogging paces, still can do 160-ish bpm cadence without much issue. If you run with music, check out some spotify playlists with 160 to 180 bpm to help you get used to it. It will feel very weird at first but it will be much better on your legs and joints.
You're probably heel striking too, and the main remedy is to increase your cadence
cherynsq
Good idea. i just subscribed to spotify . i shall try that later this evening
so basically i have to run slower but shorter strides length right? whats the breathing pattern?
noinimod
Yes. Can try this playlist (not mine). A lot of the spotify running/workout BPM not accurate with BPM all over the place.
Take shorter strides, match your step pace to the beat of the song. Breath in a regular pattern that's comfortable for you.
It will feel very weird and uncomfortable at first, like you're taking very small steps, moving your legs a lot like a shuffle, yet not moving fast. But it will get better and your legs will thank you.
cherynsq
i find it more comfortable when i breathe in from mouth and out from mouth too than breathe in from nose and out from mouth. any advice?
noinimod
Hmm this one may be more towards ENT aspect of health already.
Do you need to breathe through your mouth in day to day life? If so, there may be some nasal congestion that's preventing you from comfortably breathing through your nose. Could be either allergies or structural (enlarged turbinates/deviated septum). Will need to check with ENT to know for sure.
If you can breathe comfortably through your nose for daily activities then maybe you're jogging too hard for your current level of fitness, so need to tone it down and pace yourself
endo5x5
I just wanna come in to rant about having chosen 2XU to clock a HM result because
1) dunno if they might screw up the official distance again this year
2) income eco run is only 32 bucks for policyholders plus I heard that it is well organised (despite the silly morning rain last year)
Oh well, 53 more days. Time to clock another run this evening...
I have this weird habit of starting the only the first 3 klicks with breathe in nose and out from mouth. I dunno where I picked it up from, but I always felt that I should temper my breathing in the initial phase...
cherynsq
when running, breathe through nose abit slow. breathe through mouth, can maintain better consistency
GlassDoor
45 silver<= 12.1049 silver<= 12.30
45 gold<= 11.1049 gold<= 11.30
45 commando gold<= 10.5049 commando gold<= 11.10
45 max<= 10.0049 max<= 10.20
I am quite sure quite a few 50+ heros here can ace 2.4km under 10mins with spares. 💪
GlassDoor
加油。however you do it.. doesn't really matter. the most important is consistency. by that I mean years not months. make it a habit. the rest like running mechanics, how long to run, how far to run, cadence, breathing will sort itself out when you are more experienced.
WussRedXLi
every time I think of JC 'golden era' and stunts, I think of that ridiculous helicopter stunt in New Police Story 3
Actually he shd still be very very fit in his 50s and even up till early 60s possibly. Not sure what happened in the last 1 decade.
