Zero1 Mobile discussion thread
SPEED
Hi zero1 users. I want to port my maxx line to Zero1. In the porting part there is no Maxx option and so in this case I choose M1? Thanks
SPEED
Ok port over to Zero1. Anyway to not receive international calls? Don't want to have bill shocks. I see online says even you don't answer and reject the call will also kenna charges?
Jurong640
If you are overseas, just don't pick up, and let the call ring through. I've received calls while overseas, but not charged anything as i let it ring through.
Jurong640
So what difference did you feel with reset profile ?
The reset profile is actually adding a 5G SA VAS to your services management, move you from 4G (5G nsa) group to 5G SA.
After over a week of 5G SA usage, i don't feel any difference actually. But for some group of people who always do speed test as a hobby, you can find that 5G SA is actually slower than 5G NSA. But in actual real life usage, you won't feel any difference when surfing the web or watching videos on 5G, because the internet is fast enough.
The real difference comes during peak hours or at areas with massive people. During this time, the network will be super congested and things will load super slowly if you are on 4G (5G NSA). However, if you are on 5G SA, you are on another lane, the lanes will be wider, hence you will experience smoother loading times.
I've personally experienced Zero1's 5G SA at super crowded Singapore Airshow 2026. I do not experience any lag or slow down. I can upload my instagram stories without any slow down. Whereas my Simba on 4G, totally cannot move.
Habrosus
Z1 $15 or Singtel $15.28? Still deciding which to pick, since both 5G SA. 🤔
gapboy
overall included roam package z1 still wins .. unless you are not bothered by it and the contract you can choose the latter.
Z1 referal codes for sign up LMK if you need one
Jurong640
Yes, like what gapboy mentioned. The data roaming benefits and zero contract. You get 600GB MY/TH/ID roaming, and 20GB monthly to APAC (including China, Japan, South Korea).
Zero1 also got a referral promo too, if you intend to sign up with them, you get extra $1 to $2 off your second bill. If you want can let me know.
Habrosus
It'll be a line supporting Simba, so I guess roaming not an issue.
Thank you. 😁
Jurong640
Thank you. 😁
I see. But just take note of some differences, good and bad of each sides.
I noticed Simba APAC roaming does not include Japan, they are parked in Group A (International), whereas for Zero1, they have 20GB Japan data. However, Simba has an edge over International roaming.
