TP-Link EB810v - Quick overview
bombomlee
i bought this router from carousell, and that time i was on singtel ISP, im getting error connecting to my openvpn..
then i now switch ISP to starhub, and magically im able to connect... i oso not sure what happen...
my theory is maybe when im connected to starhub network, the router able to update and it fixes the issue...
can ask ure on which isp network?
Interested in getting this router but am on Eight. Wonder if the stuff works
taligence
Thanks for sharing.
The irony is I'm on SH. LOL!!
Maybe will explore Tailscale as an alternative.
Otokiru
the router works when i was in Singtel, except for the openvpn...
if u dont need to use openvpn then u can consider getting it...
Thanks for sharing.
btw, u able to connect to openvpn or cannot at all?
taligence
Yes, using my phone, I was able to establish a connection with the Open VPN server on the HB810V, but when I try to access the router homepage using my phone web browser it returns a 406 error.
Otokiru
ok, im having the same issue as you after able to connect to openvpn, will get 406 error if trying to access router page...
previously i wasnt able to connect to openvpn at all...
//Edited
Manage to fix the issue found from reddit
You need to enabled Second IP and add the vpn ip in Advanced > Network > LAN Settings
My OpenVPN config:
taligence
//Edited
My OpenVPN config:
Thank you so much. This works!! Finally able to log in remotely to the router page. No more 406 error!!:)
sKeLeToN
Hi all, i'm subscribed to this thread but not really actively following and not very tech savvy....so excuse my ignorance...
I've been experiencing very bad wireless connection for the longest time since upgrading to this router...even youtube is an issue. It's happening quite frequently these days.
Just like to ask if this is a known issue and if there's a simple fix?
Skypower
do the following,
- update firmware
- change wireless channel
- change wireless bandwidth (5Ghz - 80Mhz or 160Mhz)
- only connect to 5/6Ghz, ignore 2.4Ghz
- relocate router location to places more central to the house where there is less metal etc
Henry Ng
My company just issued me a wifi 7 laptop so i noticed that this EB810V is having a lot of problems with MLO and channel width 320Mhz. How to resolve the issue?
derekliu
do the following,
- update firmware
What is the ideal channel for 5Ghz and 6Ghz? i check my 5Ghz wireless bandwidth and its on 80Mhz alrdy. 6Ghz is on Auto.
Skypower
idea channel depends on location and router power output at different channel.
you may trying setting 5Ghz bandwidth to 160Mhz, 6Ghz bandwidth to 320Mhz
hi all, anyone who has successfully use this router to watch singtelTV ? I tried to configure VLAN to 20 but it didn't work.
thanks
Which SingTel plan? Using ONR or legacy ONT?
If using ONR, you have to connect SingTel TV to the ONR and not EB810v.
