- Jul 29, 2003
Yup. Both of them are Z1 beloved CSO.
oh they monitor this thread?
Not sure. But I hope so, so they want feedback what we want. Heheoh they monitor this thread?
I realise that tooI noticed Zero1 drain battery faster than my old Maxx line on my Oppo Find X9 Pro.
SIngtel 5G SA not as good as M1 5G SA ?
Lol means not only me.I realise that too
somemore maxx 5G SA speeds is much fasterLol means not only me.
Maybe port back to Maxx after few months of Zero1
Is it? Isn't it location based ?somemore maxx 5G SA speeds is much faster
generally. Maxx 5G SA anywhere i do speedtest easily minimum 500mbps.Is it? Isn't it location based ?
To hit 1gbps must be very near the basegenerally. Maxx 5G SA anywhere i do speedtest easily minimum 500mbps.
Zero1 Singtel 5G SA, places with 5G SA, got 300mbps max you must be happy liao. Sometimes lower than that. So far i haven't get any 1gbps download speed.
M1 has more coverage than Singtel?generally. Maxx 5G SA anywhere i do speedtest easily minimum 500mbps.
yes. Indoors shopping malls are quite covered. Many months back on maxx, i've hit 1gbps easily. Peak speed reached 1.34gbps.To hit 1gbps must be very near the base
I believed maybe so .. as M1 and SH shared SA infra, but the report may be accurate or not ...M1 has more coverage than Singtel?
Does zero1 5g plan shows 5G+ on your phone? Using oppo find x9 pro here. Only shows 5G but using apps to check it's already running on 5G SA mode.
AI reply:Does zero1 5g plan shows 5G+ on your phone? Using oppo find x9 pro here. Only shows 5G but using apps to check it's already running on 5G SA mode.
I know my ex phone Xiaomi 14T pro will show 5G+ with Maxx line but oppo will only show 5Gnope only some china models shows
You can try the NetMonster app on PlayStore, it'll tell you whether the base station is of SA or NSA typeDoes zero1 5g plan shows 5G+ on your phone? Using oppo find x9 pro here. Only shows 5G but using apps to check it's already running on 5G SA mode.
