Depends on your location.Means if we use router with SIM card will be useless cos the speed is capped
no, leh, my tplink 5g router antennae is more powerful than the poco phoneMeans if we use router with SIM card will be useless cos the speed is capped
IMHOPhone get lower speed than router. I have no idea why. The phone battery will be quite warm.
IMHO.IMHO
Using a phone as a hotspot is only ideal for outdoor activities or short periods, while for home Wi-Fi, a SIM router is more suitable in terms of both speed and economy of scale.
You can’t use your phone’s hotspot 24/7 without it heating up, draining the battery, and shortening its lifespan. A SIM router doesn’t have these issues.
And of course, as I always say, "to each his own".
lol you will head down a spiral lidatWhy choose $15 for 150 GB over $10 for 400 GB?![]()
IMHO. IIRC.i dunno starhub tv+ is set to 4k or 1080
content whole day burns a lot of data... google the amount yourself
my household ave 20gb/day
5g plans... data constraints
4g plans... speed constraints
IMHO.Thanks bro,
so it seems like if i want a no contract set up to watch TV (starhub tv+ app/ YouTube/dramas streaming etc)
i should at least get a 5G Sim Card router paired with 5G connection?
Am i right?
I will connect the TV by Lan cable.
Why notcan use circle.life senior plan S$5/mo @ 500GB plan?
for bonus 1t? check out the shoppee app, but i subscribed to vip, not sure if that is needed ...can use circle.life senior plan S$5/mo @ 500GB plan?
what you mean?
Please enlighten me.
Did you know the second SIM card is only free for the first month, and after that, it costs $14 per month?for bonus 1t? check out the shoppee app, but i subscribed to vip, not sure if that is needed ...
if chiu talking about quality of coverage, my 4g dies inside my life fyi ... m1 isnt as good as singtel imo ... singtel mvno are the cheapest if chiu want quality ...
circles.life just offers me $20 monthly for 1t shared between 2 sims, i use one for 5g router, the other for mobile ...router can get 5g, the mobile can only get 4g+ at home
IMHO.for bonus 1t? check out the shoppee app, but i subscribed to vip, not sure if that is needed ...
It's 20.7 per month, u need to key in promo code CLMFLMPLAN2025, it's 1t shared across 2 Sims or I'm made by AI.Did you know the second SIM card is only free for the first month, and after that, it costs $14 per month?
below is from circles.life web:
How much does Multi-SIM cost?
1 Multi-SIM: $14.13/ month
2 Multi-SIMs: $22.20/ month
3 Multi-SIMs: $30.28/ month
4g+ usuallyIMHO.
Your mobile is 4G still ?
Savings $9.20 - not much vs M1 $29.90 2.5Gbps fibreIt's 20.7 per month, u need to key in promo code CLMFLMPLAN2025, it's 1t shared across 2 Sims or I'm made by AI.
Just check bill...this is the family plan promo, not sure if it's around or changed code, try the website and see what they give u...
