jogging and motivation thread
sales69
Very HOT!!! Heat acclimatization runs starting early this year.
Out the door at 9am. 12k on a relatively shaded route with little distraction.
Back an hour ago and I am still perspiring as I type this.
Hot I like but not the humidity! Now at home already 75% RH.
Yesterday went for suntan run after 5pm. Sweat like a pig. 😂
sales69
75% consider good for me. My shoes won't get soaking wet. No need to wash. But >90%, my shoes will pond after 1hour of easy run . Need to wash after every run.
Coming few months should be 70% upwards. No more windy drier weather. :(
WussRedXLi
For Overhead Press (ie specifically "Log Lift" @ fitness corner)
Just thought of 1 way to increase weight resistance. No need for gym membership.
Use your 2.08m resistance band and lup 1 end over the long, the other end over your 2 legs. Latext bands are good. Resistance is decently nice even with the hand at the shoulder and of coz when extended it is max resistance.
BTW, as usual, before you do these more advanced movements, make sure you have good scapular stability / strength. Maybe do some scapular pull ups or even scapular circles on the pull up bar (might be even better than the pull ups) so that your smaller muscles like rhomboids / mid and lower traps
Wah youtube really everything also got
