Last day less crowdMaybe I lucky timing or most hv top up
Still got free toto bag
yes. Simba does not allow change of ownsership. You have go to zym route. Both owner must go down to Samsung store to do the port in.Hi peeps...I have a question regarding change of ownership. I understand that Simba doesnt allow such change so I have to port out to ST, M1 or SH. Is that correct?
What is the most economical way of changing ownership and then porting back to Simba?
TIA.
via cmlink. get a new number first. opt for esim if u want faster. then port over ur number and change ownership at the same time via online. you can port back to simba after its done. pls do within same month so to avoid next billing.Hi peeps...I have a question regarding change of ownership. I understand that Simba doesnt allow such change so I have to port out to ST, M1 or SH. Is that correct?
TIA.
Is it for free? Do you mean there is no lock-in period at all?via cmlink. get a new number first. opt for esim if u want faster. then port over ur number and change ownership at the same time via online. you can port back to simba after its done. i did it thrice. pls do within same month so to avoid next billing.
Thanks for the info.yes. Simba does not allow change of ownsership. You have go to zym route. Both owner must go down to Samsung store to do the port in.
i did it last year. there was no lock in. just port out within same month and make sure simba successfully ported in before end month. i applied at start of month and when cmlink was successful, i immediately ported out. which takes less than two weeks for me. it's not exactly free cos u paying that first one month of cmlink. if u worried bout deductions, just remove ur cc on cmlink site. but so far i din encounter any issues neither any deductions.Is it for free? Do you mean there is no lock-in period at all?
use cmlink for change of ownership.. easiest since can be done online.Hi peeps...I have a question regarding change of ownership. I understand that Simba doesnt allow such change so I have to port out to ST, M1 or SH. Is that correct?
TIA.
according to their t&c, either online or at their CSC, which is at either JEM or PLQ.Can I go to the partner shop (near my home) to do the port-in and change of ownership instead of online?
11. Transfer of Ownership
11.1. This refers to a change in the registered owner for an existing CMLink number, from the current owner to
another person.
11.2. CMLink supports the transfer of ownership for CMLink services. However, such transfers are subject to
conditions including both the current and new registered customers fulfilling CMLink's requirements for customer
identity validation and settlement of any outstanding payments.
11.3. Transfer of ownership requests can only be processed at our CMLink Service Centre
hi your info not accurate. i just went in see again and the link shows still can port. pls go to singapore cmlink webpage. click top right hand side. pls click the link "support" >> "number port" >>"number not under your name". pls click in and read. it still shows can be done online. if still in doubt, pls contact customer service direct and ask.
*do not go to global cmlink website. go to singapore cmlink website.*
??? are you ok?use cmlink for change of ownership.. easiest since can be done online.
i was answering to this question.Can I go to the partner shop (near my home) to do the port-in and change of ownership instead of online?
is there a need to be condescending? maybe i overlooked on my part but was just trying help here. read what u copied and pasted so i just saying it can be done online.??? are you ok?
and the t&c is from cmlink sg website.
Thank you to @nix4303 and @Charlie_Zhan for the info.
Went to check out CMLink SG website. There is an option to port in and ownership transfer via online. However the T&C states that ownership transfer must be done in CMLink HQ at PLQ. So a contradiction.
@nix4303: so if I need to purchase a new SIM from CMLink, what happened to this new number after the port-in? Do I need to terminate it?
$12 plan only APAC + CN+SK.I am on $12 plan. On SIMBA apps, on the balance entitlements show, APAC + CN, SK, JP, AU
Isn’t only those on higher plan has JP, AU?
https://www.straitstimes.com/singap...-m1s-merger-down-to-the-wire?ref=stories-cardAnd while Singtel, StarHub and M1 have parentage links to Singapore investment firm Temasek,
Simba is wholly owned by Australia-listed company Tuas
, whose principal shareholder is Australian businessman David Teoh.
