- Sep 16, 2018
if 4G is Toyota & 5G is Lexus
My opinion are both are similar in speed in Singapore
“Network Congestion“ is network capacity issue or telecom provider issue whether they can maintain service quality indicatives of IMDA… if end user can’t have reliable and reasonable speed connectivity, whose issue?
you do not paid for fishball mee and receive empty bowl then you go order zi char right?
That is not correct analogy.
Toyata and Lexus in Singapore use the same road.
4G and 5G use different network.
4G -- 4G radio access network and 4G core network
5G NSA (to shut down in the future) -- 5G radio access network and 4G core network
5G SA -- 5G radio access network and 5G core network
4G radio access network will not get upgrade. 4G core network is causing all the congestions for eight 4G.
5G radio access network will improve so the coverage will improve. 5G core network is less congested as of now and they will get improved as well.
