$0.01 just treat as donate to them la. Why make so much effort and time to make them waived that 0.01 .if u really see no open that 0.01 cents just port out .tons of telcos out there.Those who sign up for the Senior Plan at $6 (including GST), better check your bill.
I realised that in my Dad's latest bill, it was $6.01 (including GST) instead of $6.
you may think that I giam siap. But if Singtel advertise $6 (contract also stated $6 including GST), then the bill should be $6 instead of $6.01.
For the record, my mum's SIMBA senior plan bill is flat $5 per month, not $5.01 due to GST rounding nonsense.
So I complained to the Singtel CSO who say will try to waive $0.01 this time, but subsequent months need to ask again for the waiver, which is plain nonsense.
then for the recent outage, their compensation is mere 1GB of data for 1 month, which is also pathetic.
Yes. For a big organisation, it is very hard to waive for credit back 1-cent SGD. It is easier to compensate with a 1GB add-on for a month. It's 1-cent, i think should just treat it as improving their network. If one works in such organsation, you know waiving such money isn't easy.$0.01 just treat as donate to them la. Why make so much effort and time to make them waived that 0.01 .if u really see no open that 0.01 cents just port out .tons of telcos out there.![]()
To waive a bill, they need to create a component, $1 bill rebate, $5 bill rebate, $10 bill rebate and so on. I can guarantee there is no such component below $1, maybe there isn't any $1 rebate too.
To create a component, one need to draft the white paper, submit to approval, send it to IT to provision, then send it to the billing side to upload, and it takes time. Then, marketing, IT and Billing and Customer Service side need to know of this. Only Marketing can make the decision to waive. Even if marketing approve, then it takes time for billing to input that component.
I've been through all these, through my field of work. It's not possible for 1 cent waiver. If you say $5 wavier, maybe still have.
it should be $6 flat rate, right.hmm, then the bill should just indicate $6 flat after 9% GST? rather than come out with the fanciful / detailed calculation which create this round up issue?
dev at singtel earn how much?? they low ball and cut cost is it?it should be $6 flat rate, right.
In their billing component, there will be 2 components, one is GST module, one is $6 plan module.
So it's like:
SeniorPlan Module: $5.46
SeniorPlan GST Module: $0.54
Total: $6.00
So on your bill, it shows $5.51, so it's wrong, they are using the SIM Only 30 module. They might have missed out and forgotten to create seniorplan module.
Haha, how i know? Cos i created these modules before, and tested UAT and release to production.
IMHO.I do not take MRT during peak hours as I commute to work daily using public Bus services (stay and work in the west side).
But my wife does take MRT frequently during morning peak hours. She is telling me no issues with the SingTel S$15.28 plan, except minor issues at Lakeside MRT occasionally (which I suspect to be related to the aging iPhone 14 512GB version she is using).
EWL: Boon Lay to Buona Vista
Circle Line: Buona Vista to Bishan
BSL: Bishan to Toa Payoh
Using this route, she manages to avoid the more difficult EWL and NSL underground MRT stations in the CBD areas.
Based on my own experiences, Circle Line is much easier than the underground MRT stations of NSL and EWL in the CBD areas.
IMHO.
Actually I am interested in what are the actual issues.
Sometimes is technology limitation - 4G and 5G does things differently and the number of users each technology can support is different.
IMHO.old shared antenna that's what m1 told me
no idea thats what they said when i asked maxx why the reception is so bad underground EW line. I am not a Telco network engineer =)IMHO.
Eh... elaborate? Old shared antenna e.g. 3G/4G better?
IMHO.no idea thats what they said when i asked maxx why the reception is so bad underground EW line. I am not a Telco network engineer =)
GLC, what do you think is the payscale?dev at singtel earn how much?? they low ball and cut cost is it?
looks quite sloppy work that business needs not comply with technical work
Means likely old assets that isn't providing full feature, functions and compatiblity.IMHO.
