Upgrade of GPU
zihao83
Hi Guys, i tinking to upgrade my current rig to a 9070XT, not sure if existing build can manage, pls advise.
Intel Core i7-10700K 3.8 Ghz
ROG Strix Z490-F
ROG Strix RTX2060S-O8G-Gaming
DDR4 DRAM 3200Mhz C11 64GB (2x32GB)
Thermaltake Toughpower 750W Gold
Koenig168
Should be fine. The 9070XT does not have any particularly onerous requirements.
yukita
ROG Strix Z490-F
i agree, due to ram and ssd high price. i think better upgrade gpu only.
Yongkit
before you buy 9070xt check if you psu have enough cable for the 8pin power as some use 3x 8pin
zihao83
i see most 9070 needs 850w and above, most likely, need change psu too.
btw heard from my fren that 9070 will be boost if i am on amd ryzen build
using intel system is perfectly fine?or should i get a 5070 or 5070ti?
86technie
Depend which game you are playing.
RX9700 only issue if you ask is it require 3 X PCIE Connector.
Which unfornuately these days most modern PSU only comes with either 2+1 PCIE Connector.
PSU with 3 X PCIE Connector can be hard to find one.
If you consider RTX 5070 recommend to change PSU as it uses the newer 12vhpwr.
It really depend on your budget but these days RAM, SSD and GPU prices are high
due to shortage of RAM.
With ongoing conflict the situation will get even worse.
If you don't want to spend too much $, I recommend you find a used RTX 2080
which will be more faster than RTX 2060.
RTX 2060 nowadays is counted bare minimum.
I myself still uses a dated i9 9900k RTX 2080 Ti to play most of the games whether old or modern.
ragnarok95
Senior Moderator
Senior Moderator
Your 750W okie for 9070.
abstrax
ROG Strix Z490-F
9070XT can utilize PCIe 5.0. I tik ur Z490-F only support PCIe 3.0. It still can run but will be bottlenecked.
PSU can change later if ur PC keep restarting after new 9070XT installed.
zihao83
if i get a powercolour red devil 9070x & a 1000w psu to put into my PCIe 3.0, any idea how many % can i get from the gpu?
is the upgrade very significant compare to my existing RTX2060s?
kappak
300% increase
pcie3.0 minus 5 %
zihao83
300% increase
pcie3.0 minus 5 %
thanks many many~
Now any idea where can i get gd price if i were to get the GPU & PSU at gd price.
last time i go SLS, most of the shops only wanna sell the gpu if u get the full build with them
86technie
thanks many many~
You need to ask around.
For the PSU best to get one that have 3 X PCIE conenctor not piggyback.
Piggyback means use the connector from either the 1st or 2nd cable.
387138
There are not a lot of PSU with 3 XPCIE cable, check if Seasonic Focus or Vertex are available.
I only know Seasonic have 3XPCIE cable while most others have fewer PCIE cables.
