Oppo Find N6
Yuripa
Naked phone best phone
But use at own risk
Taking my time to configure the phone
5 years with one ui
Need to adjust my own ux
The in box casing is very very premium but yeah would be perfect if it came with magsafe function
Does oppo sell 1st hand magsafe casing?
NeonX
But use at own risk
5 years with one ui
Oppo china have with hinge protection
OnePunch!!
【淘宝】假一赔四
https://e.tb.cn/h.i6AuPZfeggvPZsu?tk=2HLmUA54gTL
CZ057 「【现货秒发】适用oppofindn6手机壳新款OPPO折叠屏findn6超薄壳膜一体N6保护套oppofindn5全包防摔高档男外壳」
点击链接直接打开 或者 淘宝搜索直接打开
Clear case for those interested.
maybe anyone wabba do a MO for interested
OnePunch!!
But use at own risk
5 years with one ui
ya me on iOS and S10 lite until now s25 ultra
chari-men
Do you all feel like the phone runs quite hot? Like holding hot potato sia
Normal usage or heavy task?? So far gaming performance mode and normal usage temperature runs cool.. I'm using caseless.. the only time it ran hot was battery below 10%...
tkte_85
Is it coz u still setting up/transferring data/syncing alot of data in background? Coz mine now has settled down liao, and dun forget it's actually a very slim phone by design unlike a typical candybar where it's deeper/thicker in height
BradenHeat
Some samples
I'm using the stock case to tong first and slap a magnet behind for grip socket. Use naked very slippery, may drop easily.
Anyone using ugreen chargers? Can hit pps 55w? I can only hit around 20 to 27w when I charged from 50% onwards
@SuperDecker
using Cukteck wall charger can hit high, but it will then drop to prevent overheating
CONGA适用OPPO Find N6手机壳N5
this is why i have been looking for these things for a long time coz being a Oneplus user...
have 2 spare N5 front screen TG so did a test fit, not exactly though...
How off ? the face plate case doesnt fit ? @tkte_85
felt louder
@OnePunch!!
get echo equalizer, then V-shape mild tune it, thank me again later .
BradenHeat
those who are looking,
ZMI CUKTECH NO.10 GaN 120W
shopee theres one from kkbank where i purchased, and used it for my hanoi back trips.
2pins but you can easily use a 2pin to 3pin converter​
