Oppo Find N6
progene
Charger wise. Not a concern to me. My N6 charger and cable still in box.
Me been using this charger and cable since Oppo Find X6 Pro days...has service me well.
Ray1976
Really? how? I thought the pen is charged via reverse charging on the bundle casing with the 2 pin connector to the pen.
This is how you do it...
1) Place the Oppo AI Pen kit case on a magsafe or compatible wireless charging pad or stand like so. The charger will charge the built-in battery inside the case, which in turn charge the pen.
2) Open your bluetooth settings and you should see that the pen is charging now.
3) The pen will show "Connected" to the phone. You can start using on your phone now. The pen will retain all its functionalities even w/o the case attached to the phone.
Try it.
SuperDecker
Can share the link? Super many OnePlus items on taobao, don't know if it's authentic...
Chevalier
Try it.
thanks for sharing this! I don't like the case but I want to use the pen. this is a great workaround without buying additional stuff
stupidog
Try it.
wah must buy 4756 Roll :grin: :grin: :grin:
OnePunch!!
noticed n6 vs s25u when in same lift
n6 hold onto signal so much better vs s25u
felt loading website much faster
