Oppo Find N6
NeonX
anyone using gestures as navigation?
when i want to go page back, normally, swipe right on the left side. but when i do split window, there's no issues doing this gesture for the window on the left. but for the window on the right, can't seem to do this.
No issue on mine, might need to make sure you didn't accidentally tap on the left window before using the back gesture
tohchr
No issue with mine. left right swipe also go back.
Edit: U need to "active" that windows before u slide your finger.
chari-men
Ur talking about split app two side by side or floating window?? I tested .. basically once u are scrolling via the left app.. I can swipe left or right to go back.. then I tap the right app I can do the same thing..
Yuripa
chari-men
Frankly, she deserved to have great sales as she really gives out good discount.. Salute.
Yup lol ... Plus not much foldable competition in the market at least for this year.. probably best bang for buck for early adopters Liao..
chari-men
Probably giving up getting it :(
I don't suppose you have a working link to monitor the restock right?
Is it on tian mall by the official OPPO store ?
I think some ppl use tmall.. some use direct tabao.. but same link and seller.. shipping process different only..
Computeron
I using... but opposite of urs... so I no problem
Computeron
this case is not a die die must buy.
is just happen to be "from oppo" nia.
if this case remove the brand... just aramid with hinge protection u will buy at $3x?
Yuripa
199 Chinese yuan is value for $
Got target other non oppo branded aramid fibre mag safe casing without hinge protection at ard sgd$35 but not in a rush to get it
Currently still using naked :D
