Oppo Find N6
Yuripa
Most likely have some minimum requirements to unlock but
For those who want to try their luck on shopee -
Just check back every few hours
Don't pull the trigger until you get the amount you want
So far I managed to roll 50, 75, 100, 150, 250
Instead of checking voucher page
You need to directly enter into the product page
The vouchers will be triggered and unlocked from there and it is valid for 60 mins
After that enter your own shopping cart, check tick on the products you want and then select the correct unlocked voucher from your shopping cart
Take note, once you unlock the RNG 60 mins voucher you should be able to use it for most of the items in ur shopping cart
It doesn't necessarily mean you need to use it on the specific product that you initially entered to unlock the voucher
Goodluck guys!!
Apparatus
Using the split screen for dual screens
Convenient alright but feels screens small leh
Hope OPPO release a Trifold for larger screens
:oops:
Rubick
congrats.. u the special one.. u got the 18% off cap at 500 voucher.. heng heng can buy toto liao..
I finally have this too.
But n6 up price liao haha.
No point hoot.
Gonna wait for x300ultra sua.
