Oppo confirms it has a tri-fold phone but you can't buy it
https://www.phonearena.com/news/opp...1-AN9FUQdWPkCfQqyMDE3WtSgyTHYc.5r_X7o1Fk77R.8
I'm patiently waiting for a TriFold with no-feel crease, 9000 - 10000 mAh battery and 10x optical zoom
Can I check where to find oppo camera text scanner?
what about existing photos that has text in photo albums?open camera app
under those mode scrolling until u see text scanner
actually the fastest way is just to launch photo default mode then u tap the google lens circle icon top to scan text...open camera app
ah because currently im using vxf5 and this is the way to select text from directly from existing photos from the native albumsactually the fastest way is just to launch photo default mode then u tap the google lens circle icon top to scan text...
this have to snap pic then select hor?? use google lens easier.. u just aim the text then can copy straightaway.. dont need take pic double step..ah because currently im using vxf5 and this is the way to select text from directly from existing photos from the native albums
https://www.instagram.com/reels/DJvKdPqC74p/
i just tried google lens yeah that is live on the spot point and extract the text.this have to snap pic then select hor?? use google lens easier.. u just aim the text then can copy straightaway.. dont need take pic double step..
for ur use case got another way to do this.. my snap key is default mind space.. if my colleague send me lets say a pdf file.. i just view it direct without saving.. press the snap key.. then i tap the top dynamic island i can go inside select text and copy or do whatever i want le..i just tried google lens yeah that is live on the spot point and extract the text.
but in my case sometimes like ppl send you picture(especially at work) then need to extract text from saved photos(if colleague send me documentations i save the photo to gallery then select the text from the saved photo).
not bad. haha still waiting to see whats new on vxf6.for ur use case got another way to do this.. my snap key is default mind space.. if my colleague send me lets say a pdf file.. i just view it direct without saving.. press the snap key.. then i tap the top dynamic island i can go inside select text and copy or do whatever i want le..
I use circle to search to select text and copyfor ur use case got another way to do this.. my snap key is default mind space.. if my colleague send me lets say a pdf file.. i just view it direct without saving.. press the snap key.. then i tap the top dynamic island i can go inside select text and copy or do whatever i want le..
Ah ya that also hahahah...I use circle to search to select text and copy
Those 2 in 1 with front tempered glass usually causes sensitivity issues.. just avoid that lo.. ppl buy coz convenient lol...Why so many covers got that cringe front plastic to cover the screen? I've never had one that is good before. Just want an out shell for the front display to cover the corners.
Yes. I started to miss my 小布。Ya Samsung have the better solution. But mindspace is quite awesome. Too bad we didn't get 小布
Yah that's why I don't want the 2 in 1 one. Sure will have problem, I never seen one that didn't interfere with the screen sensitivity before. Even without applying a tempered glass layer and touching the bare screen it's still an awful experience. I just want a simple one that covers the back, the hinge and the from portion flip portion corners.Those 2 in 1 with front tempered glass usually causes sensitivity issues.. just avoid that lo.. ppl buy coz convenient lol...
It's good, no need worry front bezel scratch, just have to use tape lolWhy so many covers got that cringe front plastic to cover the screen? I've never had one that is good before. Just want an out shell for the front display to cover the corners.
Probably not, even if there is you'll have to flash the Chinese rom lolYes. I started to miss my 小布。
Anyway to install on N6.
You can find alot of front covers without built in protectors on taobao though. Just not TPU.Yah that's why I don't want the 2 in 1 one. Sure will have problem, I never seen one that didn't interfere with the screen sensitivity before. Even without applying a tempered glass layer and touching the bare screen it's still an awful experience. I just want a simple one that covers the back, the hinge and the from portion flip portion corners.
U can install the breeno ai APK from apk mirror..Yes. I started to miss my 小布。
