Oppo Find N6
Waiiii
open camera app
under those mode scrolling until u see text scanner
what about existing photos that has text in photo albums?
meaning find an existing photo within photo album that has text and then start highlighting and copy/paste the text to notepad app.
c
Waiiii
this have to snap pic then select hor?? use google lens easier.. u just aim the text then can copy straightaway.. dont need take pic double step..
i just tried google lens yeah that is live on the spot point and extract the text.
but in my case sometimes like ppl send you picture(especially at work) then need to extract text from saved photos(if colleague send me documentations i save the photo to gallery then select the text from the saved photo).
chari-men
for ur use case got another way to do this.. my snap key is default mind space.. if my colleague send me lets say a pdf file.. i just view it direct without saving.. press the snap key.. then i tap the top dynamic island i can go inside select text and copy or do whatever i want le..
Waiiii
not bad. haha still waiting to see whats new on vxf6.
otherwise can wait to jumpship back to oppo find n7 next year.
bo hua to buy now and take a heavy loss on a less than 1yo foldable phone T.T
NeonX
I use circle to search to select text and copy
Vulpix
Moderator
Moderator
Why so many covers got that cringe front plastic to cover the screen? I've never had one that is good before. Just want an out shell for the front display to cover the corners.
chari-men
Those 2 in 1 with front tempered glass usually causes sensitivity issues.. just avoid that lo.. ppl buy coz convenient lol...
Vulpix
Moderator
Moderator
Yah that's why I don't want the 2 in 1 one. Sure will have problem, I never seen one that didn't interfere with the screen sensitivity before. Even without applying a tempered glass layer and touching the bare screen it's still an awful experience. I just want a simple one that covers the back, the hinge and the from portion flip portion corners.
NeonX
It's good, no need worry front bezel scratch, just have to use tape lol
Yes. I started to miss my 小布。
Anyway to install on N6.
Probably not, even if there is you'll have to flash the Chinese rom lol
Jhyun
You can find alot of front covers without built in protectors on taobao though. Just not TPU.
I usually buy those and a reduced size TG and paste normally.
progene
Had difficulty download breeno.apk.
Think, later tonight I get the APK directly from my Find X8 Ultra
