Zero1 Mobile discussion thread
AMD_Duron
Any folks here ending the ST MVNOs free X months promo from last year? How do you folks plan to strategise your connectivity needs after it ends? Given that most 5G plans are now around minimally $12 - $15/month.
I thought of getting dual lines, 1 from CL and 1 from ST MVNO which should set me around $17-$18/ month with 5G access and continue to have high availability from 2 providers, given the recent stability issues with ST. Backup providers seems like a need.
twosix
You know what will happen 6 months later? Just enjoy now. Why worry so early?
How many lines do you have now? If only single ST MVNO line, you can always start to try another line. It is pretty cheep to try a new 5G line now, S$12 to S$15 per line as you mentioned, or as low as S$6.7 to S$8 if you use the promotion codes from CL.
CL S$8 5G plan with 8GB roaming may be worth trying. Then adding Zero1/Zym S$10.10 4G plan with free 5G trial, total monthly bill will be S$18.10. Or if you do not want the hassle, just stick to ST MVNOs' S$15 5G plan, total monthly bill will be S$23.
You can also bank on free M1 Maxx base plan by paying one month of M1 Maxx 5G plan at S$12 and then stop paying.
Even eight 4G S$8 or SIMBA S$10 plan can be tested to see if it can be usable for you or not. Both may be among the worst SIM Only for local usage but both are good for roaming including free roaming voice.
All in all, there are many options for the second line even if you want to keep the ST MVNO line as the main line. You can start to try now, or you can try just before your promotion ends.
AMD_Duron
Is for wife to use. The free promo is like ending this month, looking for advice see how to keep to having 5G at lowest cost per month given the current landscape.
Your suggested option to go with CL + ST MVNO was something that is working for me now, hence thinking of it as an option to apply it as well. Just need to manually switch on phone where needed. Probably will try Eight or Simba as you said. Test how the 5G is like.
gapboy
use mazx $12
Jurong640
Every few months, promo keep changing, we shall see again in 6 months.
gaoqikai
You should be able to do that with Zero1 or VIVIFI.
Zym will charge you first two months upon sign-up. But the first month is pro-rated. So not bad either. But take note Zym may have terms and conditions to prevent existing customers in the past 12 months to enjoy the promotions.
CMLink had similar terms like Zym but they have not announced this global roaming data bundle promotion yet. Maybe they do not follow the other three ST MVNOs this time.
VIVIFI seems cannot. Their TnC also says:
If termination/ port out is triggered before a minimum stay of 2 issued bills, you will also be charged a subscription fee for the remaining months.
1st month is also pro rated
gapboy
2 issued bills
it is not really about minimum stay more on porting out and back within 12 mth period to enjoy the promotion from non ST telco.. for those was with zym or vivifi
gaoqikai
does this "12 month" still apply, when determining for current ZYM promos like free 5G for $10 plan and this new free 15GB global roaming? I don't see this 12 month mentioned in their plans page or in TnC now
gapboy
it was mentioned last time thus most of is left zym
now not sure not read anyone did get the promo
Indeed VIVIFI and Zym are similar in this aspect: minimum subscription period two months, first month pro-rated.
Zero1 and CMLink do not seem to have the above requirement but then no pro-rated first month either.
Interesting. CMLink and Zym used to have the 12 month terms very clearly stated for promotions for returning customers. Now seems no more such conditions for both.
riona
May I ask which Non-Singtel network MVNOs is the cheapest to do this port-out to and then port back in? From what I gathered so far:
Simba $10.00 min. bill 2 cycles (eSIM can activate overseas) = $20.00
Eight $8.00 min. bill 1 cycle (eSIM cannot activate overseas) = $8.00
Giga! $10.90 min. bill 1 cycle (eSIM can activate overseas) = $10.90
redONE $10.90 min. bill ?? cycle, eSIM can/cannot activate overseas?
Maxx $7.90 min. bill ?? cycle, eSIM can/cannot activate overseas?
MyRepublic 4G $7.90 min. bill ?? cycle, eSIM can/cannot activate overseas?
CL $10.80 min. bill ?? cycle, eSIM can/cannot activate overseas?
gapboy
you can refer to xiaofan thread he posted alot info ... I dont like to type alot of details on forums .. forums are more like short info exchange not like reading news :)
In short my 2 cents:
Eight
Maxx
Giga
CL - currently 4g plan is around $5/$6
rest1ess
Updated some min cycle from my exp:
Giga! $10.90 min. bill 0 cycle (eSIM can activate overseas) = $10.90
Maxx $7.90 min. bill 0 cycle, eSIM can/cannot activate overseas?
MyRepublic 4G $7.90 min. bill 0 cycle, eSIM can/cannot activate overseas?
CL $10.80 min. bill 3 cycles, eSIM can/cannot activate overseas?
Charlie_Zhan
zero1 will charge full month upon sign up and then charge 1st month's pro-rate in your 2nd bill.
