TP-Link EB810v - Quick overview
kenngks
Ok. Thanks for the very informative advice. I will stayed using AX72 as the satellite router then since using HB611-SGST will probably doesn't help.
Henry Ng
I just notice for this TP-Link EB810v Ver 2, 2.4 Ghz wifi when i set to Channel 11 20Mhz the wifi signal is quite stable and my smart camera never drop off for a few days.
mac34mac
Hi, I know this is EB810v page but I see a lot of people using HB710 too. Just want to ask if there is any new firmware for HB710? Mine is still having 0.2.0 3.0.0 v60be.0 Build 240827 Rel.44957n. Looks like no update since 2024.
And the last firmware update for my EB810v is 0.21.0 3.0.0 v608b.0 Build 250821 Rel.52033n, which is almost 9 months.
kashix
Non overlapping channel with only 20MHz, lesser interface. Sure will be more stable mah.
raindance
My HB710 firmware is dated 250418
HB710 discussions are here.
https://forums.hardwarezone.com.sg/...hb710-hb611-sgst-hb410-and-eb210-pro.7164950/
And indeed no FW updates for HB710. Older users get version 240827. Newer users get version 250418.
On the other hand, dispite the lack of FW updates, HB710 seems to be much more stable than EB810v and much less complaints in the forum.
cscs3
What's the different between eb810v v1 and eb810v v2 hardware?
Am on older v1 model. The box say it is a BE22000 router. When I check on tplink website, it say eb810v is BE19000?
Seem unable to find newer firmware to this machine.
willy792003
Actually no diff cos even with EB810v v1 BE22000, Starhub/TP-Link never implemented channel 132, 136, 140, and 144 in 5G, so it's pretty much BE19000. Unlike HB810 from Singtel. That's true BE22000 cos it has those channels in 5G
BlonkBloink
froztheart
tbh yea.... I could make it shorter cuz it just needs the gap for airflow at the base, but i made it abit higher to get a tiny bit more coverage when im in the toilet
Ahhh, that explains why.
But without a fan, would it actually help? Was there any noticeable performance difference after the stand?
cracker
Hi, need some advice here.
I had bought a HB710 and backhaul to the EB810v. The process was quick and simple.
Question
When I used the aginet apps to check firmware version, I can only see the EB810 firmware version but not the HB710. Any other way to check 710 firmware via the apps?
thx
cracker
Anyone experienced your EB810 just powered off by itself?
I had experienced it twice today..
Did the usual on/off the power point, plug in/out the power cable to the router before the unit power up again.
