jrwong84
- Mar 18, 2013
I have switched to iPhone and this phone is now used to solely collect Shopee coins……![]()
Go sell away better lah i sold mine
You're using Honor 400 Pro? Lucky I didn't buy..1 year old liao still no major Android update. Very disappointed.
seems like they didn't Honor their commitment.1 year old liao still no major Android update. Very disappointed.
Honor 400 is currently on Magic OS 10 which is Andriod 16. Is there a newer Magic OS version?1 year old liao still no major Android update. Very disappointed.
Yours is Singapore set or not? Mine got the update quite some time ago alreadyStill on Magic OS 9
Android 15
Say it's the latest. Haiz
Still on Magic OS 9
Android 15
yes, SG set
If I were to buy from Shopee, how do I know if it's using China ROM or Singapore set? It said Magic OS something...
More directly, where to I buy Singapore set of Honor 400 pro?
https://www.honor.com/sg/phones/honor-400-pro/
Click Buy, it will give you choice to buy from : Lazada / Shopee / Tik tok
no idea.Thanks. Then this is native Singapore set with Google or export set with China ROM?
no idea.
honor is good for personal use but cannot use it for work phone eg BYOMDI ordered this, after the guy said they set are all Singapore set with Google.
Didn't choose the 400 pro version as I prioritize batter life over performance or larger storage. It cost $663 after discount. The 500 none pro version going for $297 with a 5235 mAh battery and a 3.1Ghz CPU. I'm guessing the Honor 400 with a 2.65Ghz CPU and a 6000 mAh battery will be better in terms of battery life.
Reason to change, my Huawei Pura 70 battery is facing challenge once the battery drops below 40-45%. Sometimes, it will suddenly degrade very fast from 30% and below...once it hit 10-12% it will shutdown in less than 8 minutes unless I connect a charger. Then from 10% can jump to 50% in less than 10 minutes....
I think I probably abused the battery too much until it degraded like that only been used for 1 years and 4 months.
failure rate is quite high.
Bring Your Own Mobile DeviceMyomd stands for? I already ordered.![]()
