Do you use bidet?
lxb_70
What soap?
liquid hand soap or shower gel
Sent from Proxima Centauri B using EDMWER app!
sunsetbay
Moderator
Moderator
How you shoot bidet at only your butt? Your butt absorb 100% of the water?
Which type of bidet spray you using~? Handheld or toilet seat with bidet~?
The toilet seat with bidet can control the spray to shoot zhun zhun to the pigu dong~ your butt will block the water from splashing out~
The handheld bidet spray from infront, the toilet seat and butt will block the water mah unless the water pressure is too high~ :s22:
PaprikaSG
I had tried in Japan and love it.
Feels cleaner.
But I remember the first time when I used, moi press the wrong button i.e. "zhabo" button and the bidet washed my rambutans :oops:
HelIoo
outside: use toilet paper then go home use shower head wash
at home: use toilet paper and use shower head wash
Foetid
Once i had to use a cubicle without any bidet or hose, but luckily my **** came out so cleanly that after i wiped, the paper still looked perfectly white, even though i used it to dig deep deep into my anus. This was the only time it ever happened for me.
how deep u dig? u got try use rifle cleaning kit b4 to pull through?
Foetid
Yes
Now i buy portable bidet also. When go out or overseas can use
Function like those water flosser, fill up with water at toliet tap, then can spray water at pigu at toliet bowl
i never know got portable bidet? the water where u get?dont tell me scoop from the toilet bowl? or u take from tap?
electric one or mechanical pump portable bidet ah?
I_m_limpeh
Handheld by the side of toilet bowl. Company where got buy toilet seat with bidet kind??
Zinna
Water get from sink/tap where you wash hands.
The bidget can fill around 400ml, need to be slightly conservative with spraying
Electric pump, use usbc to charge
Foetid
400ml is quite alot, like the soda can...
kage
Outside bidet use is very dirty one I tell ur.
Pangsai aredy people spray using the bidet, but becos u dunno how strong is the water, the sai water will backsplash to the bidet, then some use hand wash the sai, then hold the bidet again, so ur go imagine the next time u hold the bidet is touch whose sai .... 🤭
If pangsai outside, I wet the paper hand towel then go inside cubicle pangsai wet wipe clean clean ...
At home then I use bidet and shower foam .....
:o
