Oppo Find N6
progene
I just realized my N6 inner screen got fingerprint mark.
The inner screen protector really cmi...
OnePunch!!
not bad latest updates
can😊 clone more than 1 app or games
first one among other brands max clone only one extra
KeoNxaGa
I like the feature that enable us to sort apps by colour and also able to save presets for camera's master mode
divinepotato
Color OS update 16.0.7 looks buggy. It screwed up some of my settings. Woke up this morning after an auto update, and found my alarm sound reset to default and mobile data turned off by itself. The screen brightness slider also became unresponsive for a while.
progene
I think inside one got free 1 replacement if I remembered correctly?
Hmm. I free not enough unless they allow us to paste external SP on top of it's SP. Their SP, very think and weak, easily got marks appear. Also is a dirt and fingerprint magnet. Had to wipe at least once per day...
Think, I drop by Oppo store one of this days.
BotakGirl
quick fix
dont grow long sharp finger nails esp using a fold as fold inner screen is soft
hstreamy
Can ah,just paste over the Ori one,peel it off when needed to. I have mine pasted since N5 days... Those matt type really no horse run de.
nuscape
will it damage the original SP when you take this additional SP off later?
BradenHeat
why not just OPPO Service Centre --?
What is fingerprint mark?
All those line.. that was created by my fingerprint...
When I look at the screen over the lights.. I can see those lines.
Can't.. cos can see the deep line. Think must be cos by my nails.
Dunno if we can change the default inner sp.
Won't, I had tried before removed and pasted new one.
foopower
I'm currently on this case (photo from Reddit for reference) and I don't like it - its slippery, oily and bulky. Gonna go back to the aramid casing, which feels much more premium to hold.
Waiting for my magsafe aramid back case to reach SG
BradenHeat
hows the magsafe ring ? able to dangle it and attach to other areas without dropping ?
savior1
Hi sifus - can I check if there is any suggestions for compatible front/hinge casing that we can use if I am using the AI pen default back casing?
Meaning I want to use the AI pen with the default back casing - and then if there is any compatible protector just for the front/hinge?
