Oppo Find N6
Computeron
Hi sifus - can I check if there is any suggestions for compatible front/hinge casing that we can use if I am using the AI pen default back casing?
Meaning I want to use the AI pen with the default back casing - and then if there is any compatible protector just for the front/hinge?
u using that grey free case that can hold the pen? if so just front make with a TGP can loh
savior1
yea bro.. cause I want to use the pen, and then find it abit tedious to charge the pen separately. No other way to charge the pen right? do let me know if you have any hack please haha.
TGP = tempered glass screen protector? Any recommendations or place to do it boss? do i need to remove the preapplied screen protector before applying that?
what about the hinge - any recommendations to protect it?
NeonX
You can just place the case with the pen on the wireless charging pad but the alignment is a bit finicky
savior1
NeonX
Anyone knows how to limit charging at night? My n6 charges to full for sure around 2 am, not sure if there's anyway to delay like samsung
Mclairs83
Go to battery health set to smart charging or u can change your custom charging limit to your liking.
Griggs
Did you turn on this Bedtime option in your charging settings?
Peanut15
taobao sells the hinge for the AI pen and default black case.
Taobao also sells the "front" grey case.
search for:
OPPO Find N6中轴保护条
Griggs
I have both of these turned on but am still having trouble keeping the phone from charging to full too early in the night
Did you just turned it on recently(ie. 1-2 days), it might take some time to learn your bedtime routine.
Also, do you set alarm on your phone? My previous Pixel phone time the charging based on my morning alarm, I haven't tried with Oppo though since the battery now easily lasts me 1-2 days and I've since stopped the habit of charging overnight.
NeonX
turn those option on since i got the phone, dunno why like not working lol. Even during the day when i charge it goes straight to 100%, i thought it will only go to 80% or something
Griggs
Charging limit is another separate matter, did you manually set a charging limit? You can choose from 70% to 100% in 5% increments iirc.
NeonX
not charging limit, but like ios won't charge over 80% during the day and at night it will charge to eg 90% and finish the last 10% near your waking up time
Mclairs83
need more days to learn.
if your charging pattern is inconsistent, the "learning" will not work.
bzbzbee
Hi has anyone got these marks on their hinge, making it not as smooth and shiny as other parts of the hinge. Never drop the phone also
NeonX
actually i quite consistent since launch leh. Only charge during night 12 to 1am onwards, wake up daily at 730. dunno why mine like not working haha, maybe the wireless charger i using a bit sot
foopower
hows the magsafe ring ? able to dangle it and attach to other areas without dropping ?
The magsafe ring on the case itself is pretty strong, need a bit of force from a certain angle for it to drop.
It's similar to other magsafe cases out in the market - actually it depends more on the accessory that you're using, what kind of magnets they use
KeoNxaGa
Mine don't have such marks. Have you been using case with hinge protection? if not it might be scratched when you have other things in your pocket?
bzbzbee
Nope didn't use casing. Some N6 users on xhs are experiencing this also. They said it's titanium oxidation.
