lenseview
My previous one for one topup was through shopee, so it appeared on my history as "Credit Card" then the free 88 was listed as "Promotion".
Normal topup by CC also appeared before
Never had the experience of physical top up. Maybe others can help chime in
This promo i top up at service center. Never tried before as well. So not sure. Dont know will affect or not. Did received sms and email of top up tho.
BBCWatcher
By then if never extend also too near my recharge date. No choice waste some. Try 5g, not good for my usage then drop back.
What do you mean "too near"? Turn off Auto-Recharge now if you're concerned! Then you can't be "too near," because Eight won't automatically renew/recharge your plan. Then check back on May 31 to see if Eight extends the promotion.
After you switch to the S$10.80 plan (on May 31, or later if the promotion is extended), then you can turn Auto-Recharge back on. You can also choose whether you want Auto-Recharge to continue with the S$10.80 plan or to switch to another plan such as the S$8 plan.
Easy! Eight has you covered.
lenseview
Too near as in new month is 1 june. If before june, i could just change. So if promo not extended, got to change plan before 31 may also.
Baddieko
Good to know. Did you top up this time at service center? If you did, can you see the top up history?
I topped at Clementi. Never see any topup history, only see recharge history when renew the plans. When topping up, sms came in about the topup transaction, thats abt it.
