Soundproof bedroom
loswsarah
Anyone engaged soundproof company in Singapore before? Eg Noise stop system , Consoundancy etc. Is it reliable? One of my bedroom have sound issue from exhaust fan and mechanical sounds from coffee shop below.
LWZ
yes, can ask them to visit your place and see what they recommend, no harm
mikeeeey
To be honest, if the exhaust is structurally near your bedroom and that noise is the one thats bothering you, its quite hard to sound proof it as it travels not just through sounds waves. If sound waves still easier to manage.
reddevil0728
Is your window double glazed?
reddevil0728
No, when open the window, no buzzing sound.
The sound come from wall and the floor,which below is the exhaust fan
then i don't think soundproofing will help given it's like because of solid medium
is this issue new?
Kia7200
Low frequency noise aka vibration
If u hear the noise when ur ear is on the pillow or bed then i suggest the cheapest method first.
1. Dont let ur bedframe touch the wall
2. Put a thock carpet below ur bedframe
3. Buy few thick rubber n put below to support ur bedframe
If this still does solve ur problem, i suggest u talk to the stall owner to reinstall the fan with rubber, spring or c channel to reducd vibration cause its affecting u. Can share cost or u pay for it cause its going to be way cheaper n effective than u engage a noise specialist to soundproof (decouple ur walls n floor) ur room, easily over 10k
loswsarah
Tks for ur advice, have feedback to the coffee shop person in charged to reduce the Noise, however, their side do not wish to to rectify the issue.
loswsarah
U got tell them the reinstall of exhaust fan
No. Coz I only know is exhausted fan sound, the fan pipe is big one. I not in experts to advise them how to rectify the issue. Advise them to check with their contactor, however follow up few times, give few excuse
loswsarah
is this issue new?
Yes, I don't have sound issue for the past 2 ++ years. Situation change due to change management and they installed new exhaust fan
Kia7200
No. Coz I only know is exhausted fan sound, the fan pipe is big one. I not in experts to advise them how to rectify the issue. Advise them to check with their contactor, however follow up few times, give few excusef
How u know is the exhaust fan from kopishop? U close shop no vibration?
Could be aircon outdoor unit or big washing machine
If u sure is exhaust fan, u take some photos n videos. Which show how the mount the exhaust fan n the noise of the exhaust fan, find maybe 2 exhuast fan installer online ask for solution n quote.
With the quote n solution then u approach the stall owner n decide how u want to solve this
loswsarah
Yes, is exhausted fan, when close shop, no more sound
0218crawford
mai fret TS. me tho no experience in this area, but me tink HDB will eventually ask them to put dampeners on their exhaust pipe or wat. expect only mitigation at best. if completely go away, then its a bonus liao. long term is to move. being connected to a large exhaust not only vibration, i can imagine the smell and noise from the kopitiam oso. hope your plobem settled soon.
windwaver
You stay right on top of the coffee shop? You share their ceiling?
That will be tricky if the other party refuses to corporate.
