Honor 400 Series
uncle_josh
Finally OS update came.
coyote
yes, SG set
If I were to buy from Shopee, how do I know if it's using China ROM or Singapore set? It said Magic OS something...
More directly, where to I buy Singapore set of Honor 400 pro?
coyote
I ordered this, after the guy said they set are all Singapore set with Google.
Didn't choose the 400 pro version as I prioritize batter life over performance or larger storage. It cost $663 after discount. The 500 none pro version going for $297 with a 5235 mAh battery and a 3.1Ghz CPU. I'm guessing the Honor 400 with a 2.65Ghz CPU and a 6000 mAh battery will be better in terms of battery life.
Reason to change, my Huawei Pura 70 battery is facing challenge once the battery drops below 40-45%. Sometimes, it will suddenly degrade very fast from 30% and below...once it hit 10-12% it will shutdown in less than 8 minutes unless I connect a charger. Then from 10% can jump to 50% in less than 10 minutes....
I think I probably abused the battery too much until it degraded like that only been used for 1 years and 4 months.
uncle_josh
honor is good for personal use but cannot use it for work phone eg BYOMD
failure rate is quite high.
