maedayoshiki
- Feb 23, 2012
Done. Please check. Thank you
https://s.lazada.sg/s.TSgrh?c=yDone. Please check. Thank you![]()
I didn't realise this but do recall seeing LazLand mission Merge 0/5 sometimes.Can every1 write in to Lazada CS to rectify this stupid bug where we clicked Merge invite / energy links etc 1ST instead of the missions in Lazland for Play n Play a round of Mergeboss n they will totally disappear.
Lugi 400 waters
Same bug for Play n Play a round of Gogo in Lazland missions.
Other games missions for Merge n Gogo don't hv this bugs.
Tqvm
U should hv Lazland mission Play Merge, need to click it 1st, then Play a round 5x mission will appear.I didn't realise this but do recall seeing LazLand mission Merge 0/5 sometimes.
原来 is this reason
Just checked, I don't have merge mission in LazLand, because I sent merge invite to game thread![]()
Thanks, will try to rememberU should hv Lazland mission Play Merge, need to click it 1st, then Play a round 5x mission will appear.
This is the bug, die die must do the lazland play merge mission 1st b4 U click yr Merge or other ppl link etc.
I'm a messy playerThanks, will try to rememberI'm a messy player
Today I don't see Play Merge mission, maybe because I sent Merge invite first
Edit: attach SS, total 15 LazLand mission
yes but I don't want open notification so I pass that mission.Tmr, 1st thing is to click Lazland mission should see Play Merge, same as Gogo. Then Play a round of Merge 5x mission will appear.
So good, U hv Open notification mission daily?
U can enable yr notification to take water then off it.yes but I don't want open notification so I pass that mission.
