Oppo Find X10
Elysium87
thanks for the info, i would most probably stick with x10/x10pm then. in terms of phone size, at least it would be bigger than my current which is 6.2" atm.
Chevalier
very compelling.
i have friends asking me if they should go for the 10 pro max or the x9 ultra.
i told em to wait to see what the street prices are
tkte_85
one thing i'd like to correct in terms of camera specs is that X9Pro also has a F2.1 aperture tele lens whereas X10 has brought it down to the more commonly used F2.6. Its about 2/3-3/4 of a stop more light, so it will save just that bit of shutter speed when taking photos. (but of course for a small camera sensor it might not mean much)
Elysium87
thanks, i most probably go for x10 or x10pm for better spec and extra 1 more year of software update compare to x9p now as i intend to use it for the next 4-6 years w/o changing. bigger battery too as i usually scroll content, watch CN microdrama on phone or play casual games.
idk what's the diff between x10 and x9p cpu, 9500 vs 9500m. just slightly better i guess for x10?
tkte_85
tbh i am guessing its probably gonna be very similar for the cpu. Its 9600m vs 9500. 1 year cpu tech usually dun have too big a jump esp for mediatek ones. Tbh 4-6 years is really a stretch for using a phone, even for flagship. Also the 500mah battery difference probably also wun add too much battery life imo
minuteez
Senpai, Oppo live stream on shopee now.
Bad news. Oppo X9 & X9pro no more stock. Only X9s
Elysium87
9600m vs 9500 most probably not since it's 3nm, but for x10 pro max, maybe got some difference since it's 2nm
yea x9 and x9pro everywhere no stock. x9u still have but it's fine, i wait for x10 or x10pm
sweeping
Any bought and use China ROM phones in SG before? Any downsides? My main concerns are banking apps and google pay NFC (tap to pay)
minuteez
Woah. UK Pre-Order looks good. Black Friday price guarantee also
tkte_85
CN reviewers have tested and have been seeing almost the same numbers. Another thing probably is the price, as per usual 2026/2027 phone prices will be off the roof
minuteez
Was watching Gamers Nexus recently and they were saying that the cartels negoing new LTAs to 2030 😭
Jia you CXMT! Jia you YMTC!
starlust
Oppo starts blind Find X10 series pre-orders in the UK with tons of freebies
Oppo unveiled the Find X10, Find X10 E, and Find X10 Pro Max in China yesterday. While the devices are not yet official for global markets, Oppo has already started taking blind pre-orders for them in the UK.
The company is basically offering you the opportunity to save either £150 on the Find X10 or £200 on the Find X10 Pro Max. On top of that, you'll also get your choice between a free Hasselblad teleconverter kit, a free Oppo Watch X3, or a free Oppo Pad 5. All you need to do is put down a £49 deposit and wait for the devices to launch in the UK.
