Guide to clean your Razer Mouse... solve double click issue
denniszz
Here is the guide to clean your Razer Mouse to solve double click issue...
Step 1
Find the screw by opening the rear mouse feet
Step 2
Open the mouse casing
denniszz
Step 3
Drop WD40 or contact cleaner on the click, use your nail to press on the click few times and do it twice...
With this should be able to solve the double click issue... if still cannot, please RMA your mouse.
goenitz33
will opening it up cause warranty to Void?
if yes i rather RMA :p
i read on the CH Tools pack that using it will void warranty as it will open up the mouse
tglim7
Step 3: Drop WD40 or contact cleaner on the click.....
what is tat ah? such a chimology term to me...=)
anyway, thanks for the effort dennis...great job....
jtchoy
WD40 is a oil lubricant/cleaner in a can. Both WD40 and contact cleaner can be purchased at DIY shops and most supermarkets.
Nice guide denniszz!
Litmuss
ok, finally a guide on this after waiting for so long. :s22:
KWSW
eh then the white colour thing can put back nicely one right? afraid later i take out cannot put back
denniszz
Still can put back nicely... just peel off slowly... ;)
KWSW
ok later i try with my out of warranty diamond back with the double click problem...
NightRaven
hmmm my mouse has been around since 2004 but no problems yet? someone can tell me more abt the double click issue please?
KWSW
its like sometimes i single click but it registers as double click
noobified
where to rma my mouse ah? I bought last year in dec and the right click dont seem to be working anymore.
denniszz
Please rma @ Ban Leong Serice Centre... ;)
huat86
i got a razer krait. i remove the mouse feet and there is no screw. does this apply to a krait?
djalesh
Does this really works?!? I mean i don't want to spray my mouse interior with WD40 and than nothing will change!!
Is it safe because in Slovenia new mouse like this is 63€, which is equal to $84!!
How much do, you think, will it cost if I take the mice to repair service?!?
:angel::s47:
Y2Jacky
Just to double check, what is this "double click" issue you guys are referring to?
Is it when you press the right mouse button once, it clicks twice?
