Show off your Springboard !
falcon212
SummerBoard = Change your SpringBoard icon, Wallpaper, hide/unhide label
Customize = able to change almost all part of your iphone, like Battery icon, wifi signal, badge, bar images, airplane icon, alarm icon, etc and also able to arrange icon display order
memoriess
oh , so summberboard cant re-arrange the icon display order? or can it do it too ?
falcon, you used both am i right? cause i can see you customize your 3G image.
memoriess
Err, i'm getting confused.
In Falcon's iphone springboard, there's 3 pages. and 9 apps on the 1st and 2nd page, 3 on 3rd page.
How does he do it? By Summerboard? and how to add more apps to springboard?
lurkspur
He set 'skip last row' on his Summerboard, 3rd page is only 3 icons, cos he either render the rest of his apps invisible or dont have any more app to fill the springboard :D Which I highly doubt is the case.
memoriess
but each pages can fill 12 icons, how come his only 9?
and how do he add more apps to springboard?
and how to change the icon pics if you dont like it?
falcon212
in SummerBoard theres a option to "Skip Last Row" icons, so yeah, that what i did
Add more apps to springboard? are you kidding? go to installer and install app from there, I hope you have jailbroken iphone dude
The G symbol is not 3G, iphone is not 3G phone. G is GPRS, since the GPRS symbol in iPhone by default is just a square, so i change it
To change icon? once again, use SummerBoard. MAKE SURE you restart your phone after installing SummerBoard or otherwise it wont work
lurkspur
Setting 'skip last row' on Summerboard does that, I feel like I am repeating myself =P
You need either Customize or Xlauncher to toggle your icons' visibility on springboard. To add more apps to your iPhone, dl from Installer.
The easiest is go by customized themes, which comes with customized icons. To change individual icons, you will need OpenSSH, BSD System, might be a tad too complex for you now =P
This thread will give you an idea of how it works.
http://forums.hardwarezone.com.sg/showthread.php?t=1850307
Last but not least, shouldnt everyone be doing house visiting, instead of fooling around with our springboard now? :D
memoriess
Ok, last question, falcon, how you intall those friendster/facebook/im stuffs into iphone?
and on your springboard there's a game thing, is it a folder with games inside?
hwo do you change the gprs icon? OpenSSH?
falcon212
Im using "Categories" App to categorized app in one folder, you can find trough installer
Friendster and Facebook icon i made from http://www.jonsthoughtsoneverything.com/iphone_apper/ its a webclip, since 1.1.2 doesn't support webclip so yah, must do manually :p
lerkaile
I wanna get rid of that damn 'blank block' icon where the G or E is supposed to be
